Results 1 to 7 of 7
Thread: filter driers
    Apr 2005
    My understanding is that a LL drier should be installed if you open the system for repair. I just read in the "tips" section that you should CUT out an old drier, not un-braze. What other specific situations should you always install a filter drier. When/why would you install a SL drier
    meanwhile, back at the ranch.....
    Apr 2003
    True.
    SL drier on a burnout for acid removal and to catch any debris before it enters the new compressor!
    BTW, always make sure you install it in the correct position!
    Whys that ?
    Sep 2003
    Whys that ?
    First and Foremost Any Moisture that is contained in that drier will be released into the system.
    And unless you are running Nitrogen thru the system whilst doing this,That is using your torch, you can then perhaps foul your system with carbon deposits.
    Apr 2003
    His name might be "small change", but he has the "correct change" for the question at hand!
    Originally posted by will 2
    Whys that ?
    Kinda shows my ignorance, don't it.
    In my field, you don't see any brazed driers. None.
    Apr 2005
    Thanks for the info guys. I'm sure you'll be seeing more of my questions as the cooling season gets into full swing.
