    Apr 2005
    Currently doing some research on the *new* Belimo PICCV valves.
    Has anyone ever used them yet, and have any stories (good or bad) to tell?
    Cheers.
    Minnesota
    Cheers.
    No stories. We Installed around 34 in each of two buildings on the air handlers. <Shrug> No compaints, seem to be working as advertised. Been online for almost a year now.
    Apr 2005
    Hmm
    Regarding your installation, did you still wind up using balancing valves as well as the PICCV valves for each coil?
    Minnesota
    Nope. Tho the water circulation is on a VFD system. So we did install DP sensors at the farthest (last valve) to ensure it had the minimum pressure necessary.
    Apr 2005
    Great, thanks!
