Results 1 to 7 of 7
Thread: 12 SEER !
    CH7536UKA2 is this a 12 seer 3 ton heat pump.
    is this a tempstar and is heil the same unit.
    The "Burgh"
    Could not find that one right now, but will check on Monday.
    CA75 had a 5 year warranty, so was probably not 12 SEER, but can verify on Monday. And yes, it is a Heil/Tempstar and yes they were the same at that time
    Burleson, Texas
    CA55 is a 10,CA75 is a 11, and CA95 is a 12.....
    Back then Heil & Tempstar were 100% identical.
    11 SEER, but would depend on the coil a little bit.
    Early 90's unit. Serial will tell you.
    Jacksonville, FL.
    Still are, aren't they?
    Yes, but Tempstar does have some different cosmetic looks on SOME of their models. Some of their condensors have a slanted top and some of the Tempstar furnaces have SS front doors.
