Thread: duct board shaping and cutting
04-23-2005, 01:49 PM #1
- Apr 2005
- 3
anyone know where I can find info on the shaping ( angle cuts etc.)and cutting of duct board. I haven't worked with this stuff in 12 years but now have a job where much needs to be installed.
I tried Owens Corning website hoping to find a pdf file of link but came up empty handed.
04-23-2005, 05:54 PM #2
Try a google search. I found a couple of pdf's, but I'm not on my computer. This computer doesn't have Adobe. I searched for "ductboard cutting procedures". Try to re-phrase if you still come up short.
If this doesn't help, ask the local supply house to get you a copy of the paperwork that comes with the purchase of the cutting tools. I don't own the tools, but I'm pretty sure the instructions that come with the tools has all that information.
Get back to work.™
04-23-2005, 06:41 PM #3
- Oct 2001
- Waterford Michigan
- 2,666
Knauf Air duct fabrication Manual or NAIMA fibrous glass duct construction standards. http://www.naima.org
http://www.jm.com/insulation/technical_info/2949.htmhas some fabrication info.
04-23-2005, 10:21 PM #4
- Sep 2004
- 3,157
we have machinery that cuts our ductboard but we made a tool to cut circles with using a piece of 1/2 x 2" flat aluminum
along the length of the flat bar on the c/l holes are drilled and tapped 1/4-20 on the radius of each size and on the end a razor knife blade is attached with an end cap that is also drilled to accept a #10 screw-the end of the flat bar having two holes drilled and tapped to match the holes in the cap
everyone that uses one has been happy with it. I dont know if that helps or not
04-24-2005, 11:03 AM #5
- Apr 2005
- 3
Thanks for all the feedback. I ordered the guide from NAIMA should be here within 12 days.
