Results 1 to 13 of 29
    Feb 2011
    inter city products gas furnace problem
    Hi Everyone
    working on a inter city products gas furnace
    Model NDGG100DF03
    867.766132 ( i think this is what it is as it was hard to see )
    ok we put a new thermocouple on it ( we didnt have or could get the right one at the time so we made one fit) and it worked good for 3 months or so then wouldn't kick on so we got the right one for this model still didnt work we then found a rollout switch had tripped reset that and it work good for a few hours we check it again found the same rollout switch tripped so we put a new rollout switch on it worked good for a few hours then would not kick on so we put a new thermostat on and set it for 68 F well then it worked just fine for 2 or 3 days then same thing will not kick on and the roll out switch tripped so the guy at the house tells me that when they set the hest up to about 70 or 70 F is when it stopped working ... so now we are thinking that the fan limit switch maybe the problem ???? so times the fan will run but no heat on ( customer said it just blows cold air some times ) we also check both rollout switchs and the vent switch all test ok
    it seems that when they turn up the heat is when it tripps the rollout switch the guy said he turned it down when he went to bed last night and today when they got up he turned it up and and after it kicked off it wound't kick back on
    anyone have any idea ??
    thanks
    Washington
    Quote Originally Posted by xboxman View Post
    Hi Everyone
    Model NDGG100DF03
    thanks
    Get up to 15 posts and apply for pro membership. Can't help you otherwise due to site rules.
    Old 60%er? Rollout trips? I'd suspect bad HX. Time to replace.
    Sep 2009
    Arnold mo
    Get an experienced tech on this one. Could be something dangerous. The roll-out is probably just doing its job.
    An answer without a question is meaningless.
    Information without understanding is useless.
    You can lead a horse to water............
    http://www.mohomeenergyaudits.com
    Sep 2009
    Arnold mo
    I just can't remember seeing any old 60%'ers with rollout switches. Also, I can't remember seeing rollout switches in the same furnace with a thermocoupler.
    Jul 2010
    Caledonia,Ontario,Canada
    Just keep changing parts, I liked the changing of the thermostate it seems relevant .....
    Feb 2011
    i think i saw on the model info tag 1990 not sure if thats the date on the unit or not but it may be
    thanks
    Feb 2011
    Quote Originally Posted by khc95 View Post
    well the other guy some how got some wires wrong and blow the old thermostate LOL so we had to put on a new one on
    Washington
    No DIY. Call out someone who knows what they are doing before someone gets hurt.
    SE Michigan
    Hi Everyone
    Model NDGG100DF03
    thanks
    "If anybody can draw on the power, where do we put the meter?" - JP Morgan before pulling Tesla funding
    Jul 2010
    Quote Originally Posted by coolwhip View Post
    Ya I just chuckled thru the whole thing....
    In a boiler room
    Have you tried a new filter?
    You can keep putting parts on it or you can call a reputable heating contractor and actually get it fixed. Unless its beyond repair.
    Washington
    C'mon, parts changers need love too!!
