Results 1 to 13 of 20
Thread: Carrier econo gears
02-05-2011, 12:44 PM #1
- Feb 2011
- colorado mountians
- 117
Carrier econo gears
Has anyone run across carrier economizer gears cracking at drive hubs? i'm looking for a fix. i dropped actuator to second gear and reversed rotation,but of coarse it cracked. local carrierdealer said no replacement parts available so instead of a $5 gear i have to replace a $2500 econo. i have 19 units on this roof 6 need gears. lubed all bushings and freed up blades i dont look forward to dropping this big dollar repair on the customer. any advise whould be appreciated
02-05-2011, 01:21 PM #2
- Apr 2007
- Pa
- 738
they are plastic, correct? You could try to weld it, I never did but I have welded up PE towers and PVC pipe. Or you could look for a local shop that makes plastic parts or a cnc shop for plastic work. Hell you could look for a plastic sheet that is the same material/thickness and use one of the gears and make a template. Take a dremel and do it yourself
02-05-2011, 02:59 PM #3
- Feb 2011
- 117
its like pullin teeth to get anything up here in the mountians. the gears are plastic, dont think making them is a viable option. the way they attach to act. and blade is definately a blown plastic design. still cant believe micro metl / carrier doen,t have parts for these things. next time i'm at this place i'll see if i can Macgyver some thing
02-05-2011, 03:36 PM #4
Professional Member*
- Jan 2008
- Dallas ,Texas
- 3,512
A model number would be nice.
UA 100
It takes three people to do anything around here. Two do the work, one explains to the crowd of people who showed up when they seen smoke and flames.
02-05-2011, 05:08 PM #5
A-Have a shop cast it in loss wax and make a sand casting -inexpensive mold
B-Have a injection mold made -expensive mold
C-Have a CNC programmer make you a program to CNC the part into I would suggest 6061T6 aluminum. I was a cnc programmer. use to make all kinds of stuff on my off hours for guys.- on the cheap
D-Find one on ebay or something or rig something up maybe your gear will cross over to another make model...
E-Have the gear repaired by a shop preferably as stated previously by a plastics shop.
F-Change manufacturer design. I have been known to use a Chane and sprocket in old equipment.It takes courage to grow up and turn out to be who you really are.
- E.E. Cummings
02-05-2011, 05:49 PM #6
- Feb 2011
- 117
these are 48HGDT14AB-60KD5 UNITS. thanks chrisvacman, unfortunatly it would prob. be in denver to find such a shop (200 miles one way) to find said type of shop i havnt let my fingers do the walkin yet, i'll look around
02-06-2011, 12:15 AM #7
There is a fix for that style of econo with the plastic gears.
Is the actuator mounted to the side of the damper assembly with a small shaft that fits into the square hub on the plastic gear ? And the square hub is what cracks right? not the whole gear?
if so
The fix is drilling a hole through the center of the gear, slide the new longer shaft through the gear, use a bracket to attach the new shaft to the damper blade, and reinstall the actuator and tighten it to the new shaft.
I installed this on a smaller carrier, but I heard of guys at our shop using this fix on the same size unit you're talking about.
Our shop had the parts made by a machine shop, but I thought that carrier has these parts as well..
02-06-2011, 12:32 AM #8
- Feb 2011
- 117
thanks y7turbo, i was thinkin of trying some thing like that. all carrier out here is willing to do is sell the whole frickin econo package. btw spent 38 yrs in chic. 13 @ local 597. hope you guys are staying busy
02-06-2011, 12:55 AM #9
- Jan 2008
- Dallas ,Texas
- 3,512
Is the gear broken or just stripped out? You can also just use a piece of 3/8" all thread , roll pins , and some 3/8" coupling nuts. That`s as long as the gear is not broken.
Bad thing about these gears is that Ruskin I think JCI owned them, used to make lots of economizers then I think JCI became a Carrier competitor when they bought York. And it`s kinda hard to get some injection molding company to retool up reproduce cheap gears that there isn`t much demand for.UA 100
02-06-2011, 12:44 PM #10
- Feb 2011
- 117
thanks guys, the hubs on these gears are broken, not the cogs themselves. this unit actually "slugged" a scroll and stressed the spot welds on the side of the can to the point of loosing charge, leakin like a beech. newer units too
02-06-2011, 12:51 PM #11
- Jan 2008
- Dallas ,Texas
- 3,512
02-14-2011, 07:26 PM #12
It's a horrible design, as soon as the econo gets some dust in it the gears bind against the sheet metal and the actuator dies or the gear hubs strip out. I have made the repair by replacing the gears which, while not a fun job is possible and cheaper than a new econo. Carrier never seems to have a handle on MicroMetl products. Maybe because micrometl changes their design as often as Carrier does. Moving forward, silicone at the inspection keeps the gears from binding.
___________________________________________
These Are The Good Old Days
02-14-2011, 07:59 PM #13
Finally. I have a good answer. Good and cheap. I had the same thing happen to me. The white plastic gear splits at the square hub in the middle. I placed a gear clamp (hose clamp) on the hub. It pulls the cracked part back together thereby keeping it from spreading apart again.
ENJOY THE RIDE
