Results 1 to 6 of 6
    Apr 2005
    Hey guys maybe you can help me. I have a 2 ton 12 seer Goodman package unit and I have wired everything up, I though correctly, however when I try to flip the breaker it throws. I have 2 pairs of wire coming off the HP one for the emergency coil heat and one for the heat pump itself. I have 2 30 A dual pole breakers one for each wire. The emergency heat breaker works fine, however, the heat pump breaker throws anytime I try to flip the breaker. I have a 60 amp shutoff switch on the outside of the unit and have run from that to inside the pump to the 3 connectors inside. I have also used a 18-7 gauge wire for the thermostat and I think that is fine also. Can someone help please. Is the shutoff switch possibly messed up? Or could the thermostat wires be throwing the breaker?
    Thanks,
    Cedric
    Nov 2000
    Eastern PA
    Have someone who knows what they are doing look at your system. It would be irresponsible for any of us to try to walk you through this.
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    Florida
    Electricity can be fatal. Make the phonecall.
    Apr 2005
    I am aware and usually do a pretty good job with electricity. I just got done upgrading my house from a 100A service to a 200A service. I believe it is just a small error inside the unit. I guess what I am asking is their a common mistake that is made with heat pumps that could cause this problem? From the breaker to the shut off on the unit the electricity is fine. It's somewhere between the shutoff and the heat pump.
    Thanks,
    Cedric
    Nov 2000
    Eastern PA
    The only way to trace electrical issues is with test meters on the job. This is not an area conducive to guessing.
    Sep 2001
    Vancouver Canada
    on your shutoff make sure the line and load are wired to the right terminals. Look inside it should say in the switch which is line and which is load. Other than that, call an electrician. Sometimes cheaper than letting the smoke out of a bunch of switches and parts.
