Results 1 to 9 of 9
Thread: auto ac
    LA
    Has any body used SUPERHEATOR SUB COOLTO CHECK OR CHARGE AC
    The only correct way to charge an automotive AC system is by weight.
    Maine
    Yep, the weight is provided in the owners manual under specifications, also a label under the hood has the info.
    Florida
    Yeah, but when the label's gone and the book is lost......
    With no label to use and it's realllly hot out, I've just thrown in enough to get a cold return.....frost on the suction line works just fine. Gotta keep the compressor cool and lubricated.
    Apr 2005
    Tampa, Florida
    Head over to Barnes & Noble, Border's, etc. They usually have a good selection of Chilton reference books which would have that info.
    Houston,Tx.
    http://www.autoacforum.com/
    Good auto a/c forum I have been a member for a few years.
    take a friend that can read english with you and go to the
    LIBRARY . Most citys have several of them and they have a wide selection of auto repair books there
    Mar 2001
    go to http://www.aircondition.com/wwwboard and post your question there. Ignacio, Warren and the others there will be happy to help.
