Results 1 to 7 of 7
    Feb 2011
    York 600 ton YT Chiller will YK VSD work?
    I have a York YTL1L3E3-CTGS 600 Ton Chiller, I would like to know if a VSD503 K-46 Freq drive will adapt to my chiller. Please advise!
    Nov 2005
    Shreveport, Louisiana
    Did someone quote you this work or are you just looking?
    UA Local 141
    Jun 2009
    StL, MO
    You should probably ask a moderator to put this in the Chillers forum.
    UA LU 562
    Somewhere in the world.
    There is a lot more info. that would be needed like a full VSD part # because there are different variations , you would most likely need to replace microboard with it this is serious money upgrade to this machine. Unless you work directly for the factory I wouldn't recommend it.
    A mind is like a parachute. It doesn't work if it is not open.
    The best part of going to work is coming back home at the end of the day.
    Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all.
    Jan 2011
    North Carolina
    There are 5 different "styles" of VSD's and as york56 said, if you have a part number it will tell you exactly what style and the last 3 digits will denote obviously YT retrofit but its basic or with filter.......CHA-CHING$$
    Dec 2006
    Chicago, IL
    What controls are you using? I could be wrong but I remember hearing that the VSD retrofit requires the newer optiview control panel.
    Jan 2011
    North Carolina
    The Optispeed drive can be connected to either Microcomputer Control Center or an Optiview Control Center. Doesn't matter which control system is used, the functions of the vsd components perform the same, although different controls will determine related keypad functions. The optispeed uses multiple microprocessors and digital signal processors that are linked through a network of parallel and serial comm. links. i.e, microboard and acc(adaptive capacity control) boards. I think this is what york56 was eluding to. Hope that helps....
