Results 1 to 6 of 6
Thread: Somethings not right
04-21-2005, 07:42 AM #1
- Mar 2003
- 293
i go on a call for no cool yesterday.
Indoor unit is running
outdoor fan is running.
compressor is not running.
Our company just installed a new a-coil maybe 2 days ago. The customer is not happy.
I threw my gages and thats when I became confused. Granted the compressor was not running. My low side was 0psig while my high side was at a saturated outside temp 75.
I checked the compressor windings and the terminals were burnt up.
so what confuses me is the 0 psig on the lowside. Could a restiction burn up the compressor? Did the installer of the a-coil not test the unit? Is this just a sad coincidence for the home owner?
It is a 84 intertherm in a beloved mobil home. So it very well could be bad luck. the condensor was not in good shape.
I just thought I'd throw that out.
04-21-2005, 08:19 AM #2
too many "ifs" to be sure...regardless of what happened the customer is convinced that you caused the problem..now you need to sell a new condensing unit (which should have been sold in the first place) to match the new a-coil..possibly a burn out with contaminated line set..clean it up and put in a suction line dryer
04-21-2005, 11:22 AM #3
Your company installed a new A coil on a 21 year old A/C unit? Live and learn..... I'd sell the customer a new complete system and take the complete cost of the A coil install and your trip out there off of their bill, and explain that you were trying to save them $$$ but it didn't work, and don't ever do it again. You're either going to lose a customer and get bad-mouthed, or gain one from being honest and rectifying the situation. And don't jack the price to cover the a-coil.....eat it and learn to hate the taste. JMO
04-21-2005, 06:08 PM #4
- Oct 2002
- Mahopac NY
- 448
[QUOTE]Originally posted by smokin68
Your company installed a new A coil on a 21 year old A/C unit? Live and learn..... I'd sell the customer a new complete system and take the complete cost of the A coil install and your trip out there off of their bill, and explain that you were trying to save them $$$ but it didn't work, and don't ever do it again. You're either going to lose a customer and get bad-mouthed, or gain one from being honest and rectifying the situation. And don't jack the price to cover the a-coil.....eat it and learn to hate the taste. JMO [/QUOTE
Good advice.Dogs truly are man's best friend!!
04-21-2005, 08:33 PM #5Originally posted by timmay
A scroll compressor will go bad if run in a vacuum.
Did you double check to make sure the rubber around the depressor in your hose didn't collapse?
i.e. Check low side pressure with your high pressure gauge.
04-22-2005, 07:40 AM #6
- Mar 2003
- 293
i didn't think of that. I need to always consider it though but don't. Twice I've had some screw ball readings and its cause the rubber is not holding up. i need to get some extras and make sure to maintain.Originally posted by wormy
[/B]
thats a good idea for a topic.
