Results 1 to 10 of 10
    Feb 2011
    Make up air for woodstove
    I have a new house which I am going to install a free standing wood stove on the first floor. The house is in northern Michigan and is heated with radiant floor heat provided by a high efficency boiler provided with outside combustion air. The question I have is what is the best way to provide make up air for the wood stove per code. Currently I am thinking of installing a Condar ASV vent near the stove since I then can control the vent. Will this work or what are other ways of doing this.
    May 2005
    Madison, WI
    What about the outside air kit sold to work with the stove?
    You could put an in-line damper in it to close it if needed, closest the end (outside) as possible.
    Feb 2011
    I do not have one that came with the stove. Also it is just a hose with a box that mounts to the stove and it will not look right in the great room.
    Altmar, New York, United States
    it a code to do this? shy of just a vent through the wall i don't think any would look appealing. do you have a basement?
    Feb 2011
    Smyrna, GA
    This Air Supply Ventilator is manually adjusted. Will you be opening when you start a fire then closing when fire and all embers are gone?
    When you say new home, I expect that it is brand new and built to comply with tightness codes. If so, how is your dryer supplied with air? Clothes dryers vent straight out too and need make up air.
    Madison, WI/Cape Coral, FL
    Along the same lines, how do you provide fresh air ventilation for the home?
    Regards TB
    Aug 2011
    Ontario
    HRV
    There is no bad beer, some just taste better than others.
    Quote Originally Posted by rm-mi View Post
    You need enough powered make-up air to avoid any negative pressure that is generated by the clothes drier/kitchen hood that could backdraft a smoldering wood fire when the clothes drier/hood and anyother exhaust device operates. Wind direction and velocity also get to be an issue.
    Regards TB
    Jun 2008
    Madison, WI
    I definitely would use a sealed combustion system with direct vent (like your boiler likely has nowadays). when you don't do sealed combustion you will:
    -draw in cold air to make up combustion air; your oven room likely will be warm, but the rest of the house will get cold
    - assuming your house is tight, you may starve the stove or draw combustion products in your house; the stove gets too little air and combusts less completely (more CO, HC etc.)
    - if you use a manual damper or air supply ventilator to let air in I see the issue of a code violation since code likely requires a fail-safe automatic ventilation. At some point in time someone will forget to open or close that damper. Even if code is not an issue, it is not good.
    Most wood stoves are designed to have sealed combustion for that reason. You seem to have a boiler set up the same way. in principle the boiler is the same as a wood stove, except it uses different fuel. but combustion products and air supply issues are the very same. So treat them the same.
    Nov 2011
    vancouver island canada
    In a tight house wood stove can kill just like a gas appliance due to oxygen depletion or the production of CO under the wrong conditions. Feed the combustion air directly so the fire has no direct communication with the space it is heating. If this means an ugly pipe then so be it. The alternative is less pleasant (death)
