Results 1 to 4 of 4
    Feb 2011
    two stage furnace runs constantly
    I just registered and hope this is where you can ask a question. I just had a Rheem two stage furnace installed and it seems to run too frequently.
    It runs for 12-13 minutes, shuts off for 5 minutes and starts up again and runs another 12-13 minutes.
    I keep the temp set at 64 and it will run even if temp is 64??
    Is that the norm
    Jul 2002
    Yuma, AZ
    It won't hurt the furnace if it ran continuously.
    Run time depends on the weather and house construction. Sizing, air leakage, insulation, door opening and other factors matter a lot. The DOE says that the average waste in ductwork due to air leakage is 25 to 40%. If you don't like the fuel consumption, the first thing to address is air duct leakage.
    "I have never let my schooling interfere with my education."
    Mark Twain
    NEVER STOP LEARNING.
    Jul 2002
    Yuma, AZ
    Quote Originally Posted by lelka View Post
    Is that the norm
    With electronic stats, the on and off temperatures can be as close as 1*F. This can be set to be wider to reduce cycling if you find it annoying.
    Mark Twain
    Nov 2010
    Kansas
    Welcome to the site,
    This is just the intoduction forum, you would be better off to post questions like this in the residential hvac forum where you will get more responses and the mods won't lock the thread.
    Good luck and take care.
    The statement below is my signature and just my overall feeling towards our industry and does not necessarily pertain to you nor this thread.
    There really isn't a legitimate excuse for not doing the job correctly!
