Results 1 to 13 of 21
    Feb 2011
    two stage cooling wire
    A contractor is replacing my old bryant system with a trane XR15-XV80 system. The existing thermostat wire has two conductors to the outdoor unit, but the trane system has two stage cooling and requires three wires. The existing wire is run through a two story wall to the attic so probably cannot fish a new wire. The contractor gave me two choices:
    1. Run a new 3 conductor wire along the outside of the brick, through the eave and into the attic.
    2. Use the existing two wire conductor and use the the copper refrigerant line as a third wire.
    Option #2 looks better, but it sounds like a hack. Any suggestions?
    thx
    Jun 2008
    Cincinnati, Ohio
    I vote option #1, as long as the wire is in conduit.
    This guy seriously suggested using the refrigerant line as a conductor?
    Feb 2011
    yes, he said it would work.
    I had three quotes for this install and he pointed out defects in the existing system that the other two guys missed. This was the only questionable point and he gave me a choice, so i guess i shouldn't be too concerned.
    Aug 2010
    Little town in Texas
    Refer line?
    Quote Originally Posted by phbsales View Post
    I have used the (insulated) suction line..temporarily..maybe twice..but by all means..not a permemant fix..smh
    "If you can’t describe what you are doing as a process, you don’t know what you are doing." ~ W. Edwards Deming
    All those who wander..are not lost.
    Do NOT..mistake my kindness for weakness.
    The early bird may get the worm..but the second mouse gets the cheese.
    Washington
    Quote Originally Posted by bobskurka View Post
    That's a new one on me!!
    He either runs the new wire or he doesn't do the job. That is what I would tell him.
    Why does everyone make such a big fuss about cutting out a little drywall to conceal wires?? Drywall fixing is the easiest thing to do in the construction trades. You will be much happier in the long run if you spend the money and take the time to do it properly at this time.
    Jul 2009
    Plant City, Florida
    thx
    #2 is hack
    Use a wireless thermostat.
    Jun 2008
    Cincinnati, Ohio
    Quote Originally Posted by bwalley View Post
    #2 is hack
    Still has to be hard-wired from the RF base to the OD unit, wireless or not.
    Jun 2008
    Cincinnati, Ohio
    Quote Originally Posted by lions_lair View Post
    Operative word being "temporary".
    St Louis, MO
    There are folks making wireless solutions like a Jackson Systems "wireless relay" wr-400, think they have even been advertising on this site a bunch recently.
    Nov 2002
    Lisle,Illinois
    Talking
    XR15 is single stage condensing unit,XV80 is 2-stage heat variable 80%afue.
    Ethics are as important as education.
    Dec 2001
    Ocean Pines, MD
    Run it down the drain line.
    Jan 2011
    If the upstairs system has a secondary drain line that runs down stairs, you can have him fish the wire down through it. Ive used that trick on a straight drain pipe to replace a liquid line.
    It truly would not hurt anything if he used the refrigerant line as a conductor as long as he is substituting it for the "common" wire, and i'm sure that is what he was intending to do. Just make sure he runs a wire from the refrigerant lines in the attic into the furnace to the "common" terminal instead of relying on the unit housing to do that job. It's a little hack, but it does the job and there are no disadvantages to doing it. It will not hurt the xv80.
    just caught that- hmmmm XR-15. You sure thats a two stage cooling unit?
    Jul 2009
    Plant City, Florida
    I think there are systems that have a unit for the condensing unit, air handler and also the thermostat.
    The honeywell systems need a control wire from the A/H to the condensing unit, so they aren't completely wireless unless being used on a package unit.
