Results 14 to 26 of 35
Thread: ucp2
    Somewhere in the world.
    attached is the closest i could get to swahili
    You are quite the individual multi functional real men of genius we salute you mister swahili interperter.
    A mind is like a parachute. It doesn't work if it is not open.
    The best part of going to work is coming back home at the end of the day.
    Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all.
    ottawa canada
    Hmm
    this chiller does not have 'softload'...at least not like it is applied to the other screw chiller products.
    Jay is correct , but what I was referring to was you could send it a variable current limit signal over a set time period and do the same thing .
    I still would like to know how adding extra Ct's will solve his low evap temp issue though ???
    Quote Originally Posted by graham View Post
    ...what I was referring to was you could send it a variable current limit signal over a set time period and do the same thing...
    or a variable chilled water setpoint.
    ...I still would like to know how adding extra Ct's will solve his low evap temp issue though ???
    it is a swahili thing...you wouldn't understand.
    Mar 2010
    Va.
    Is a VFD installed on the chill water pump?
    Dec 2010
    Central US
    If im not mistaken the RTAA UCP2 has phase unbalance & phase reversal already, Just need to confirm its enabled under setup menu.
    Ya'll are right its standard ambient unless low ambient option has been added.
    What is your chw setpoint, what is the ambient condition its tripping????????
    ottawa canada
    No ...i think I'm getting this Swahili thing now ........
    So my refrigerant charge is contaminated ,,,,,,,,,,,,, so if I change the M1 circuit #2 contactor auxillary interlock it will fix it right ?????
    Mar 2010
    Va.
    Anyone open a control panel just to find a rats nest of wires and wonder how that could happen?
    graham, It's too cold in Canada for that Healey. I think it would be happier if it were parked farther south. I know a perfect garage in Va.
    Not in Iran
    graham
    [QUOTE=
    I still would like to know how adding extra Ct's will solve his low evap temp issue though ???[/QUOTE]
    it wont., every body know this , just as my 7 year old., haha
    thanks graham
    no signature blast'em man blast'em
    !!!KILL THE TERRORIST!!!
    ...so if I change the M1 circuit #2 contactor auxillary interlock it will fix it right ?????
    NO! NO! NO!
    that is how the russian ones are fixed....geez....isn't anyone listening?
    see the attached document for that repair.
    Not in Iran
    Unhappy no no no
    here it is guyz
    Jun 2008
    Quote Originally Posted by Phisher View Post
    as long as the pump is the right size no need for a vfd on the loop
    Not in Iran
    got it.,.,
    got it., i know that there is 2 types of ct's., reg ct's and under and over voltage., .,.,
    1 MOTOR OVERLOAD
    2 CONTACTOR DROP OUT OR NOT WELDED SHUT
    3 LOSS OF PHASE
    4 ROTATION
    5 UNBALANCE
    WHERE AS THE under over transformer
    IS JUST THAT.,.,
    HAS NOTHING to do with the low ambient.,.,
    Dec 2010
    Central US
    Hmm
    Quote Originally Posted by mlkwal1 View Post
    1 MOTOR OVERLOAD
    3 LOSS OF PHASE
    4 ROTATION
    5 UNBALANCE
    IS JUST THAT.,.,
    You mentioned low evap alarm and other problems due to low ambient conditions. Do you really have isues or was this just a jab session??
