Results 27 to 35 of 35
Thread: ucp2
02-03-2011, 09:17 AM #27
- Mar 2010
- Va.
- 178
02-03-2011, 10:05 AM #28
- May 2008
- Central Pennsylvania
- 415
02-03-2011, 05:35 PM #29
02-03-2011, 05:37 PM #30
02-03-2011, 05:55 PM #31
NO! NO! NO!
that is how the russian ones are fixed....geez....isn't anyone listening?
Ok Im off to Siberia .......probably about the same temp there as here so I'll be right at home .
graham, It's too cold in Canada for that Healey. I think it would be happier if it were parked farther south. I know a perfect garage in Va.
Yep its cold but spring is coming and I can see the finish line for the car ......just in time .You bend em" I"ll mend em" !!!!!!!
Whooo Hooo spring at last , time to get the toys out ........vrrrroooooom !!!!
02-03-2011, 06:00 PM #32
no drive on the machine going to check out compressor capacity , temp sensors, and inverter.,.,
If theres no drive on the machine how are you going to check the inverter ?????
Am i reading the wrong IOM again ????? Do i need the Chekoslovakian version
JAAAAAYYYYYYY HEEEEEELLLLLP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!You bend em" I"ll mend em" !!!!!!!
02-03-2011, 06:08 PM #33
here it is guyz
Attached Files in chineese writing.pdf
No wonder your having trouble fixin it .......thats the wrong manual ?????????????You bend em" I"ll mend em" !!!!!!!
02-03-2011, 09:05 PM #34
DON'T USE THAT CHINESE VERSION!!! there has been an upgraded IOM.
for those that care, on page 8, center column, under bullet point #2 they say that the heaters are DE-ENERGIZED when the chiller is off. It was supposed to say that the heaters are ENERGIZED.
at least that is how i read it.
here you go (ends in CS)...and the norwegian one too with some of the longest words that i have ever seen!Time to get my nerd on!
02-03-2011, 09:24 PM #35
Cant open the Nerwegian version Jay .....the words must be to big for this computer?????
Do you have a Gaelic copy instead ?????You bend em" I"ll mend em" !!!!!!!
blast'em man blast'em
