    Jan 2005
    Does anyone know the number? I am installing an SV 80 power vent. 3 low voltage wires coming from venter. One white says W from furnace. 2 more wires one is white and one is purple. Anyone have any idea?
    There should be a wiring diagram somewhere - See if you can locate it, or go to http://www.goodmanmfg.com .. Good luck
    Nov 2000
    Eastern PA
    1-888-593-9988, tell um Robin Boyd sent you.
    Government is a disease...
    ...masquerading as its own cure…
    Ecclesiastes 10:2 NIV
    Apr 2004
    Robo... why isnt the distributor the point of contact for tech support? If not, what is the need to have distributors? Seems to me, people start thinking there is a bank of 200 experts sitting by the phone waiting for any one of the 200,000 contractors to call.
    Just curious
    Nov 2000
    Eastern PA
    The distributor is the first point of contact for tech support. But if the particular distributor that the tech is dealing with cannot accomodate that tech, Goodman has a backup system.
    W would be power from the wall thermostat to the power venter relay. The second wire would be common from the LV transformer or circuit board. Third wire would be output from the pressure switch to W on the circuit board at the furnace.
    Im not looking at any diagram , just thinking about it. I could be wrong.
    [Edited by appltech1 on 04-17-2005 at 02:04 PM]
