Thread: Redo?
    Apr 2005
    Does this suction line need to be done over?
    Picture removed.
    [Edited by jmm706 on 04-15-2005 at 12:14 PM]
    Houston,Tx.
    Don't bump the unit with the lawn mower it should be ok, I don't know why they did not bend or form the copper up the line to fit straight in, maybe was short on copper. Looks like a goodman unit it might feel right at home with that weld "just kidding"
    Fort Worth, TX
    http://www.imagewiz.net/usr/hvac1/3798_ACLine.jpg
    I'm guessing your installer isn't familiar with 45° copper elbows.
    How'd he get the bottom side to seal up? Gobs of brazing?
    Building Physics Rule #2:
    Building Physics Rule #3:
    Houston,Tx.
    Originally posted by shophound
    I'm guessing your installer isn't familiar with 45° copper elbows.[/B]
    heck Shop, that's another 25 cents you know how tight some of these a/c companys are.
    Apr 2005
    I guess it was a mistake by a junior installer. The company took care of it quickly and neatly. Turned out to be great guys. Thanks for your input.
