Results 1 to 9 of 9
Thread: Unit freeze up
    Apr 2005
    London Ky
    Okay. Just bought my home. Turned on breakers three days ago. All is well. Using a little heat but no Air. Went outside this morning and the whole unit is frozen.What seems to be the problem? Freon?
    Can any one help?
    burlington county n.j.
    sounds like defrost problem. shut off and cal for service.
    Apr 2005
    Niagara Falls,NY
    Question
    Is the outside fan running? Did you check the hi/low pressures? Need more info to help you
    Apr 2005
    London Ky
    heard the unit trying to run but, no fan movement. No I havent checked pressures
    Cheech,
    Ed had the best suggestion. Shut it down and call a local company for a full inspection.
    Apr 2005
    Niagara Falls,NY
    Do you know how to use a multi meter to check the fan for power? If so check it when it is trying to run. It is probubly cycling on low press switch. If you do not know how to check it safely then call for service. If you do check it and thats not the problem then you might have a defrost problem .
    chicago suburbs
    wonder boy this is not a DIY site. read the rules.
    FILL OUT YOUR PROFILE!!
    Apr 2005
    London Ky
    Hey thanks for the help all.
    a certain amount of frost will be visable before it goes into a defrost cycle,did you leave it run long enough to be sure it wasn't in a defrost cycle?The fan stops during defrost.
    Did you turn it off ?
