Thread: When
    Apr 2005
    When testing both the a/c and the heater (gas)which unit should you operate first, how long should you wait in between tests?
    SE Michigan
    What are you testing for?
    "If anybody can draw on the power, where do we put the meter?" - JP Morgan before pulling Tesla funding
    Apr 2005
    Just simple operation tests to see if the units work.
    It really doesn't make a difference. Right cool?
    Maybe you are asking because you are worried about heating up the evap coil with the gas heat and starting the condenser too soon? Maybe there will be a heavy start load on the unit?
    Just yell "fire in the hole" and hit the switch.
