Results 1 to 13 of 18
    Apr 2005
    Fort Worth TX
    I have a Tracer Summit running on ver 11 with an older IBM P2 computer. It has ISA slot arcnet. I'm in the process of upgrading front end to an IBM P4 and of course it does not have ISA slots. I have purchased a PCI arcnet from card from Contemporary Controls. Contemporary Controls tell me that I need to install drivers from the Summit Software. How ever XP Pro has not located them and the files that Contemporary Controls says will work "CCSI_ARCNET.INF" and "COM20020.SYS" are not on the Tracer Summit V11 software. Any help on these drivers or other drivers that will work with Tracer Summit V11 and XP Pro would be Appreciated.
    Is there a reason your not upgrading to ethernet. You have to replace the cabling- Arcnet coax is not capatible with ethernet.However CAT5 wiring is cheap and easy. The length limit for CAT5 is 330ft. How big is your site.How many BCUs Just seems this would be the time to upgrade everything.The ethernet card can be bought from Trane parts dept and real easy to install. Just a thought. Good Luck.I'll look around for your arcnet drivers.
    As far as I know XP does not support Arcnet at all. Arcnet card is looking for Ndis component of windows to interact with computer hardware, after windows NT4 service pack6, windows dropped Ndis all together if I remember correctly.
    I am recalling this from memory long long ago.
    I don't think a solution will be easy if you want to stick with Arcnet.
    Good luck.
    Apr 2005
    Fort Worth TX
    I really would like to stay with the Acrnet. If I chose to change to ethernet I have been told that my BCUs would have to be replaced as they do not support ethernet. I am also told the drivers for the PCI Arcnet are to come from the summit software. I have left a message for Trane but have not heard any thing yet. I.m hoping that the drivers are on a newer version and that it will work with version 11. I'm not sure that the BCUs will support a higher version than 11. The system was put in with version 10 in 2000 and upgraded to ver 11 later that same year. The system has 2 BCUs , 46 PCMs and 1 UPCM currently running 98se and the Arcnet is for an ISA slot. I don't have a problem with it's operation it is just that the front end pc has been running continuously for five years and PCs dont last for ever. All the new PCs dont have ISA slots so I am changing to the PCI Arcnet which is rare. I'm not upgrading just trying to survive. Thanks for any help.
    Jan 2002
    If I remember right, you will not find anything that will work on arcnet on the xp platform for Summit. It is another lovely way that American Standard does not give backwards compatability to almost anything. You can purchase the ether cards pretty cheap but it gets kinda complicated cause you have to have a certain ver bcu and the chip has to be at a certain level. If you do a search on the commercial side there was a discussion about the upgrade procedure with card and chip numbers I believe. Or maybe a helpful Trane man might chime in? (qtip?)
    Two wire hook up, three wire f**k up.
    If you really want to stick with Arcnet, then I suggest:
    Upgrade computer hardware
    Use PCI card that you have
    Reinstall win98se
    I do not have them, but I know Trane has Arcnet drivers for PCI cards but this will only work on win98.
    I would also put some future plan in place to slowly convert to ethernet.
    In my opinion, in one way or the other you will be forced to do it as time passes.
    Summit interface
    I have seen one Summit unit connected via a Fieldserver media converter to a WIFI accesspoint - very handy and easy to configure since it is standard ethernet. The PC to Summit connection may be connected this way.
    dc, if you are really stuck, one other option maybe to buy a protocol translator box, BACnet ethernet to BACnet Arcnet (with BNC connector). This gateway usually is transparent to the system. This way the PC can use an ethernet card, and the BCUs can remain with Arcnet cards.
    these are not cheap (~1K - 2K) but they work.
    One of the companies that make such a thing is:
    http://www.cimetrics.com
    And there are other companies.
    On the bay fishing
    One of the guys at the office just did the same thing. I will talk to him on Friday.
    TRACER Summit Arcnet Drivers
    To get a arcnet driver for Win XP or 2000 you need a PCI arcnet card and Tracer summit version 12 with latest service pack to get arcnet driver. You can upgrade old BCUs to ethernet if the ROM chip on the BCU which would probably be a BMTS model is a version 4.0 or greater. The chip can still be ordered from trane for the older BCUs. Hopefully this helps.
    PS. Ask about a free software upgrade to version 16 tracer summit.
    On the bay fishing
    Arcnet drivers for XP are located on Summit V16 disk.
    Apr 2005
    Arcnet drivers for
    Call your local Trane office, Trane is upgrading Summit from ver 11, 12, 13, 14, 15 to ver 16 for free.
    They will try to charge you for installaton, but the software is a free upgrade. It was only a $100.00 upgrade to about three months ago, now its free. I have upgraded
    several customers. The arcnet drivers are on the ver 16 disk. and it works. You can convert to ethernet real on older BCU's. BMTS. Their is a Boot rom chip you can get
    from Trane, about twenty bucks. The trick is finding a ISA
    ethernet card for the BCU. Trane wants about a hundred bucks for that card.
    What do you know, Arcnet drivers for XP!
    Learn something new everyday.
    A question for Trane Corporate boys:
    Do you ever wonder why your controls support division gets bigger and bigger with more headaches?
    Oh..., I forgot "can't stop a Trane."
