    Apr 2005
    Niagara Falls,NY
    Question
    How can you find out if a system has a proper refer charge by only using guages and a p/t chart? Ive always either weighed in a charge or used a glass charging cylinder.
    southern illinois
    super heat-subcool....and other measurements as well...
    Feb 2002
    a thermometer is also very useful!!
    leland nc
    you cant charge a unit with only gages
    go through some on the earler post on chargeing mothods and read them
    then you can do it right
    Columbia, SC
    Look to see if there is some data on the unit, a piece of paper that tells you all the information on the unit, if you have it. Then you can match up the pressures to that and be pretty dead accurate.
    southern illinois
    what's a matter don't you trust your air conditioning guy?
