Results 1 to 7 of 7
    AX not retaining Fahrenhiet
    Ax is defaulting to C. Each time it is started the user has to go to Menu/tools/options/unitconversion but it is only temporary.
    Mount Airy, MD
    User profile set to?
    New Hampsha'!!!
    yea sounds like that users profile is set to unit conversion to C. does it work fine if you log in using a different user?
    dont worry what people think, they dont do it often
    Not sure I was there for something else. What is the location of the User Profile?
    Look at the specific user.
    Found under Services-->User Service-->specific user.
    If you look at the user there is a property called unit conversion, make sure it is set to the proper setting.
    Another place to look is Tools-->Options there is another spot for unit conversion.
    When I go under SystemService there is nothing titled UserService. Going to Tools>Options does work bu tit reverts to metric after signing off. There is Users unjder the navigation but nothing about units.
    Mount Airy, MD
    Station>Config>Services>UserService should be where all the users be
    Brand of workbench, screen shot, something else for us???
