View Poll Results: Should the Chiller Forum become Pro Only?
Voters
110. You may not vote on this poll
  • Pro Only, I want to share better info
    72 65.45%
  • I want two Forums, Pro and Open
    18 16.36%
  • No, don't change it
    20 18.18%
Page 6 of 10 FirstFirst 12345678910 LastLast
Results 66 to 78 of 119
  1. #66
    Aug 2009
    Jurupa Valley, CA
    I guess it depends on WHY you're talking about going to the pro forum. I was under the impression that the reasoning behind the pro forums was to limit access to privileged information, business discussions, and to prevent 'amateur' access. I understand this, perhaps, for the residential forums - but for chillers - I guess i just don't see much of a problem with amateur's even coming in contact with a chiller, let alone attempting any significant maintenance.
  2. #67
    ottawa canada
    Im kinda on the fence . I can see and understand the reasons for going pro but when all's said and done if the hacks want to have a go then let them. When the screw it up they can get the guys who know how to fix it to do it right and we make lots of money doing it .
    Also some of the posts really add to my amusment on a friday night .
    So I say leave it be .
  3. #68
    Aug 2009
    Jurupa Valley, CA
    Quote Originally Posted by graham View Post
    Honestly, sometimes I feel the fear isn't the hacks screwing the work up, but actually getting something right...
  4. #69
    Jun 2010
    U.A. (upper Alabama)
    I got a good question, I think. What if this chiller forum does go pro only, and it looks like it probably is, how are the chiller mechanic guest, that want to get on here later going to become a pro? Are they going to have to get their post count up in the residential section or the commercial section? It will be hard to tell if someone is really a chiller mech. by post on residential or commercial . Also there are still a lot of good techs. out there that don't know about this site yet.
  5. #70
    Somewhere in the world.
    If they are truly a chiller mechanic even if they post in the other sections I am sure that someone will still respond to them but any critical info. will not be provided unless someone has decided to give it to them.
    A mind is like a parachute. It doesn't work if it is not open.
    The best part of going to work is coming back home at the end of the day.
    Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all.
  6. #71
    i'll probably have to leave this forum open but will have to move stuff as it gets complicated and i would need you guys to tell me to "move to pro" via the report button.
    this is what we had to do in the control forum.
  7. #72
    windy city
    Hmmmmmmmm.............where is this report button I keep reading about?
    \m/
    original member of the racoon brotherhood
  8. #73
    windy city
    Ahhhhhhhhh no. Never noticed it, to tell you the truth.
    And it does what? Lite the 'Bat Lite' over gotham?
    \m/
  10. #75
    windy city
    okie dokey.
    \m/
  12. #77
    Atlanta GA area
    Quote Originally Posted by heavymetaldad View Post
    It is a hot-line to the mods and Lusker...
    Most folks use it to either report something... good or bad; or suggest something.
    GA-HVAC-Tech
  13. #78
    Second City, USA
    What the Chiller World Needs
    Been so long since I even signed in I couldn't even come up with my log in info. Previously it seemed to me that there was very little of the kind of help I needed. I've more than 35 years as a UA member involved in the servicing and maintenance of chillers and more than 30 of those years was with an OEM. Working fo a mechanical contractor, I no longer have a steady diet of one manufacturers chillers and have run into a lot of things that were not "second nature". With all the changes in equipment and the evaporating supply of service literature made available by the OEM's I can see that there is a real need for a forum where "pro's" can openly exchange, both materials and experiences. While it's not clear to me what protection a pro chiller forum affords, it sure sounds like a good idearrr!
