Results 1 to 4 of 4
    Apr 2005
    Hi All,
    I’m going to have central air installed in my home and I have a few questions.
    First, and probably the most important how do I find a quality contractor?
    Second, I have 100 amp service in my home with no major electrical appliances (no electric stove, water heater, dryer etc.) and would like an opinion on if I can use the existing service for the new air conditioner? I have a 1500 sq ft ranch in Northern NJ with high quality windows and average insulation so I’m guessing I will need at most a 3 ton unit, what is the electrical requirements for a unit of this size? I know the contractor will spec out the real #s but I'm hoping for an educated guess if I will need to budget for an electric upgrade as part of the installation. I have a 220v 10-3 electric line that was used by a previous owner for an electric dryer available for the compressor unit if this is sufficient.
    After reading a good number of posts here I am leaning toward the Carrier Infinity as a top choice unit. I have high humidity in my area and the Infinity looks like a good performer for humidity control. Does going with a Carrier “factory authorized dealer” give me a better quality installer? Thanks in advance for your help.
    Rich V
    Apr 2005
    Farmingdale NJ
    I assume you have hot water or steam heat. and the AC system will be separate with new ductwork. I am in New Jersey and a Trane Dealer. Carrier, is a good piece of equipment, so is Lennox and so is Trane. You need a good installer.
    Most 3 ton a/c units require a 30 amp service . 1 or two may require 35 amp maximum breaker but a lesser ampacity. Either way 10/3 gage wire is sutible.
    West TN
    Carrier Authorized Dealer Info (place in bottom left to enter your zip code to locate someone in your area)
    http://www.residential.carrier.com/res/details/0,,CLI1_DIV109_ETI8442_MID4032,00.html?SMSESSION=NO
    More info on Infinity
    http://www.residential.carrier.com/res/details/0,3041,CLI1_DIV109_ETI8551_MID3655,00.html?SMSESSIO N=NO
    Trane Residential (be sure to check out the Trane System customizer)
    http://www.trane.com/Residential/ResidentialHome.aspx
    Locate a Trane Dealer (Look for a Trane Comfort Specialist)
    http://www.trane.com/Residential/Dea...ealerInfo.aspx
    Lennox
    http://www.davelennox.com/default.asp
    Extend to others the grace that God has given you.
Quality Home Comfort Awards
