Results 14 to 19 of 19
    Originally posted by bwal2
    Originally posted by Toolpusher
    I don't believe I've ever heard of nitrogen being able to change state,
    It's an inert gas.
    There are only six inert gases:
    helium, neon, argon, krypton, xenon, and radon.
    Nitrogen is not inert.
    If nitrogen is not inert, then what does it react to?
    Dec 2001
    It's an inert gas.
    Same with CO2. It is also an inert gas. I think I'll start using xenon or neon to purge and leak test. Wouldn't that look interesting on the invoice?
    Tyler, TX
    from: http://legacystory.apps.em.doe.gov/t...ose/close8.htm
    "Inert gas. A gas that does not react chemically with other substances. The inert gases are helium, neon, argon, xenon, and radon. Also occasionally used inaccurately to refer to nitrogen."
    Nitrogen and Carbon Dioxide are both acceptable for use as a purge and leak test gas in processing a refrigeration system.
    However, neither are technically inert.
    I don't know what material either gas is reactive to, but there are only six truely inert gases.
    Google it up.
    Post back with what you find.
    RSES Certificate Member Specialist
    Southwest Regional Association of RSES Secretary, 2017
    Mar 2002
    Nitrogen is reacting with my St. Augustine grass right now!
    It loves the stuff.
    I found it the other day.
    The 1 site has a mpeg of that is cool to watch.
    I was always told it was an inert gas, you taught me something.
    Tyler, TX
    That's what I do.
    What site?
    Post the url here.
