Results 1 to 13 of 19
    Old lady's system next door apparently still has her system charged with nitrogen.psig's on both sides equeal at 150 with system running.First thought was bad valves until I found system was full of nitrogen.Does anyone know if a compressor with cap tupe metering device will condense nitrogen enough to get low and high pressure readings?I don't want to waste the effort if her valves are shot.Doin it for free, so any help is appreciated.
    Nov 2001
    I don't believe I've ever heard of nitrogen being able to change state,
    It's an inert gas.
    Which have you done ?
    South Dakota
    It's an inert gas.
    Any gas can be liquified given enough pressure. Nitrogen will not condense in an air conditioning or refrigeration system. The system operates at pressures far below the condensing temperature-pressure (saturation) of nitrogen.
    Oct 2001
    Waterford Michigan
    Now how would the system get full of nitrogen?
    Nov 2001
    sorry I'll go back to my cornor now
    South Dakota
    1. If the system is full of air it already contains 78% nitrogen.
    2. Nitrogen is often put in systems for purging during brazing at the time of installation and is also used for leak testing. All real technicians carry nitrogen with them.
    Suppy NC
    no
    remove the nitrogen
    evacuate the syatem and wiegh in the proper charge
    look at the name plate and find out what kind of refrigerant is being used
    if you run it with nitrogen you will blow the compressor
    grodan1
    I can’t believe anyone would leave nitrogen in the system, without locking out the compressor circuit. How did you determine its nitrogen in the system?
    With equal pressures hi and low with compressor actually running, would indicate a defective compressor, or if a heat pump maybe the reversing valve.
    (are you sure the compressor was running and not just the fan operating)
    Jun 2002
    Bemidji, Mn
    Coulda been worse and said oxygen!
    You picked a fine time to leave me loose wheel...
    http://rapalaguy.spaces.live.com/
    How did I determine it had nitrogen in it? I remembered what happened at school when students took their hoses off without first bleeding the liquid refrigerent in their red hose into the low system so only vapor was in hose.When that happened a bunch of liquid refrigerent came shooting out.So I purposely took my hoses off wrong in the way to make sure my red hose would still be full of liquid.When I opened it (slowly,so I could shut it off if it was refrig)my presssure went from 130 to nothing and it sounded weak as a pop-corn fart.Plus the old lady said "they"said they would return and put refrigerent in her system when they returned, but they never did.
    Oct 2001
    Waterford Michigan
    Where I'm from here we call air, air and nitrogen, nitrogen. All real technicians know this regardless if they carry nitrogen or some other inert gas.
    It's an inert gas.
    There are only six inert gases:
    helium, neon, argon, krypton, xenon, and radon.
    Nitrogen is not inert.
    Anything and everything will change state, with enough temperature and/or pressure change.
    That being said, nitrogen is one of the things we refrigeration people call "non-condensables".
    That just means it won't change state at the temperatures and pressures found in your normal, run-of-the-mill, air conditioner. (so you were right.)
    (You have heard of liquid nitrogen, right? Same stuff. Doctors use it to freeze warts.)
    Niantic, Illinois
    Has she tried contacting them. If she hasn't even tried then how does she know whether they are willing to take care of her or not? Don't just assume they will not. Someties people fall through the cracks by accident.It's happened to all of us.
Comfortech Show Promo Image
Comfortech365 Virtual Event
