    Hi,
    I am adding a new 12 seer 2 ton packaged system to a home and installing a NEW return air filter.
    I am making a 24"x24" by 6" deep filter slot and plan to run a merv 14 pleated filter.
    is this overkill???
    what brand of filter would you suggest.
    thks
    diddly Yes this sounds like over kill. What is the resistance of this filter? Have you looked at the space guard.
    Jul 2002
    Franklin
    Originally posted by diddlywhoot
    Hi,
    is this overkill???
    thks
    Go with a MERV 11 from Abatement. Go to http://www.heritageheatingandcooling.com for the link. This is about the most you need. Actually an awesome set up for the money.
    compensate for the pressure drop ... we use merv 8 ... that is enough
