Results 1 to 7 of 7
    Question
    what do you guys do on a condensing furnace in an unconditioned space to keep the drain from freezing? would you opt for an 80% furnace or protect the drain?
    We prefer 80%. Hard to find drain freeze protection that is 100% effective. 90s in attics are rare here but usually find one fiasco a winter with one.
    In our area, any furnace that's in a cold space will fail, unless specified "outdoor use", ie. a rooftop unit etc.
    so, would you try to find another location or just go with the 80%
    Rochester, MN
    I'd find another area where it will not drop below freezing..
    Or stay with the 80% if you are not able to find an area to keep it warm.
    Jun 2002
    Bemidji, Mn
    NEVER put a high-efficiency furnace in a non-conditioned space, Just asking for trouble IMO.
    You picked a fine time to leave me loose wheel...
    http://rapalaguy.spaces.live.com/
    I agree,but I have seen heat tape used not sure if it worked out.
