Results 14 to 24 of 24
    Jan 2011
    Oh then mine isnt to far off.
    At 450 the month
    Is your basement finished with r14 on walls?
    Mar 2009
    Russell ON Canada
    My basement walls have R21 down to the floor. We had the house built in 1994 when it passed the R2000 certification test with about 35% to spare.
    Jan 2011
    I just found out my walls are r20 and 2x6
    How much heat woould i lose out of my basement? Its unfinished
    Sep 2009
    Iowa
    Don't they offer a seperate meter for all heating aspects on electrical for you guys? Also how much is your $/kwh? To me it seems a little high. Hard saying without being on a seperate meter from the rest of your house. Does your thermostat tell you a run time or anything? I've installed roughly 150 geo systems in central iowa. The best i've seen we did was about $48/month for a 3800 sq/ft house well insulated and around $60/month for a 6,000 sq/ft house well insulated. Of course our temps don't get as cold as you guys. We still dip below 0 for atleast 2 - 3 weeks total out of the year
    Sep 2009
    Iowa
    it almost sounds like a duct problem to me as well. which thermostat are you using with the system?
    Jan 2011
    60 for heating costs alone? I dont seperate geo with other items
    My total cost is for everything
    Do you happen to know what that 6000 sqft house pays monthly total?
    My geo is running on stage 1 most of the time...probably 20 hours a day
    Right now its minus 12
    In summer time we dont use alot of AC and our total bill is around 200 to 250
    On budget billing im spending around 390 a monthy in total that includes everything
    Apr 2010
    southern california
    Quote Originally Posted by velcomrob View Post
    I am a little confused, in your first post you said the units were running in second stage and could not keep up, the wife and kids were freezing, now the unit is running in first stage 20 hours. 9 tons of geo should be enough for your size home. Your bills are not outrageous. Your rate is .10kw/hr and costing you about .65 cents/hr for your electric needs during the winter months. This is pretty cheap compared to how cold it has been. I would like to know more about your the loops, like how many, how deep etc.
    Jan 2011
    Sorry i wasnt clear
    the system would not reach the level we wwnt on stage 2 alone.
    I had aux heat turned off.
    So i decided to let it run or we would freeze.
    Stage 1 runs all the time when the temp is around -10.
    When its -20 and below then it needs aux heat frequently.
    So i guess all this is normal.
    Hope it makes sense now.
    Apr 2010
    southern california
    What make and model do you have and be specific about your ground loops.
    Jan 2011
    Do you mean model of the of the geo system?
    Apr 2010
    southern california
    Yes, the model of the geo and how many loops went into the ground.
