Results 1 to 13 of 15
    May 2002
    Anyone have a K factor chart for VCW boxes?
    Nov 2003
    Boston
    I have a list of Flow Coefficients from a Siemens manual that lists a Trane box as 0.66.
    It does not list model numbers and I don't know how old the list is.
    Hope that helped.
    May 2002
    Baton Rouge, Louisiana
    Sys is this the older boxes or the newer ones?
    I have a IOM manual on these model boxes in Pdf form and at the beginning it says for air balancing instructions see
    EA10_IOM2-E, the manual I have doesnt have the K factor but the one I just listed should.
    Dad's Hideout The online mancave for dads
    Washington,NJ
    If you know the inlet size of the box, regardless of manufacturer, the number will be the same. A 10" box is a 10" box, ask any balancer.
    May 2002
    ...you know you say that and they all end up being a little different. What's the reason is what I want to really know.
    Washington,NJ
    Even if they are the slightest bit different, your balancer should give you the proper multiplier to compensate for that, but I know what your talkin about!! I'll check my online info for the Trane VCW box and get you the correct info, hey man, don't you ever sleep? Bacnet rules!!
    May 2002
    ... too busy fighting the ASHRAE BACnetter propaganda...
    if somebody would send over a cape I'd be set.
    May 2002
    Sys, see my post above, that should be the manual you need
    Hampton Roads, Virginia
    Keep up the good fight, we need you!
    "Profit is not the legitimate purpose of business. The legitimate purpose of business is to provide a product or service that people need and do it so well that it's profitable."
    James Rouse
    Sometimes K factors are....
    ....the amount of CFM a box will deliver at 1 inch of differentialpressure.
    San Diego, CA
    reviving this thread... I was looking for the same thing, found this IOM dated June 2006. See page 32 for an updated pressure differential vs cfm flow chart with actual box sizes.
    http://www.trane.com/Commercial/Uplo...av_unitiom.pdf
    Sep 2006
    Alaska
    Trane K Factors
    Duct Size Area K Factor
    5 .14 3.27
    6 .20 2.65
    8 .35 2.44
    10 .55 2.30
    12 .79 2.30
    14 1.07 2.30
    16 1.40 2.27
    This is the chart I have for Trane, hope it helps!!!!
    San Diego, CA
    HW spudders ask for the k-factors as box CFM @ 1 in w.c.
    What's the conversion from your method?
