    Jan 2011
    Carrier Centrifugal
    Anyone know the procdure for calabraiting the vane drive on a 19RX machine?
    MEXICO
    Checking Guide Vane Linkage — When the chiller
    is off, the guide vanes are closed and the actuator mechanism is
    in the position shown in Fig. 37. If slack develops in the drive
    chain, do the following to eliminate backlash:
    1. With the chiller shut down and the actuator fully closed,
    remove the chain guard and loosen the actuator bracket
    hold-down bolts.
    2. Loosen guide vane sprocket adjusting bolts.
    3. Pry bracket upwards to remove slack, then retighten the
    bracket hold-down bolts.
    4. Retighten the guide vane sprocket adjusting bolts. Ensure
    that the guide vane shaft is rotated fully in the clockwise
    direction in order close it fully.
    Cartersville Ga
    Quote Originally Posted by rhfoxx View Post
    Go into the controls test, scroll down to guide vane calibration and push select. If it fails more than likely it is the vane potentiometer.
    Fort Worth, TX
    Quote Originally Posted by SteveBelcher View Post
    Yep. I had a vane pot on one of my 19XR chillers develop a "flat spot" and send back erroneous info to the PIC. A new pot solved that problem.
    Building Physics Rule #2:
    Building Physics Rule #3:
    Dec 2010
    I am looking for a spec sheet on a series 17 chiller?
    job#2200D6031
    ser#18602
    machine assy. no. 17p30-D3.5-r3-1
    Any info would be helpful.
