Results 1 to 13 of 17
    Plattsburgh NY
    Hmm
    Hey everyone, I don't post much but I have been watching for a while. I thoght maybe I could gain some insight. I did a leak check on a Ducane split yesterday and had a hard time recharging the system, just couldnt seem to clear the glass. I tried the usual by putting jug of 22 in bucket of hot water, and gave up after a few hours, and I guess I'm going to go back on a warm day to top charge off. Is there any tips or tricks you guys want to donate? Any advice would be greatly appreciated.
    Jul 2002
    St Paul, Minnesota
    What was the ambient?
    Nov 2001
    did you find the leak ?
    If you try to fail, and succeed.
    Which have you done ?
    Urbandale IA. USA
    Weigh it in!
    The Model tag should tell you where to start.
    Check the superheat and subcooling!
    Was this high efficiency (12 SEER or higher)?
    TXV or piston?
    Apr 2004
    Unless it was too cold to put the refrigerant in, I'm thinking its overcharged now. Paint over the sight glass, you dont want to use that on residential stuff.
    Plattsburgh NY
    Outside ambient was about 55F, I've got a 30 degree deltaT across indoor coil, in at 70 out at 40, suction press. 35 discharge press. 115, suction temp at comp. 50 degree, these are approx. readings from my recollection 2 days ago. So I'm pretty sure I'm undercharged. Just looking for some tips and tricks to move r-22 into unit at low ambient temp.
    Jan 2005
    gotta...
    Gotta get that head pressure up...try wrapping a tarp or sheet of plastic around the condenser
    Plattsburgh NY
    Now there is a possible answer I am looking for. Air mechanix, so your saying by driving the head press. up this will help move refrigerant into system at low ambient?
    Houston,Tx.
    What color Doc?
    30 degree drop? You ain't movin' much air! Do the customer a favor, go back on a warm day. Wrapping the coil simulates a warmer day but most charging charts ask outdoor temp. What is "outdoor temp" on a 55 degree day with plastic around the coil? If charging a piston system properly, you need indoor wet bulb. In cool weather, so low it is off the chart.
    Glendale AZ
    Edit
    [Edited by danj on 04-06-2005 at 09:16 PM]
    The bitterness of poor quality remains long after the sweetness of low price has gone.
    Plattsburgh NY
    Thanks bald loonie. Waiting for warm day. and as for the above statement about painting the sight glass on residential stuff, what do you suppose he's talking about, we all know superheat says it all.
    southern illinois
    we don't charge until 70 outdoor,....but i do remeber last year on here they were talking about tents or maybe turkey blinds or something to go over condenser.
