Results 1 to 13 of 25
Thread: Another hydronic geothermal job
01-23-2011, 09:53 PM #1
Just finished this job and wanted to get a few pics up. Still waiting for Mech insulation, I will post updated pics when done. This is a fire station with 3 infloor heat zones and will have chilled water cooling later on from the 2- 10 ton heat pumps.
Remember, some poor fool has to work on what you install someday, and it might even be you.
01-23-2011, 11:39 PM #2
- Feb 2005
- L.I. NY
- 125
Looks good, the only thing I do not like is in the middle photo the back wall.
The 2 center lines straight thru the tee's will flow more that the outside lines that are on the side outlets of the tee's.
01-24-2011, 06:14 AM #3
Professional Member*
- Dec 2002
- SouthEast NC ICW & Piedmont Foothills
- 7,219
how do you like the crimper?
had any issues with it?
01-24-2011, 10:41 AM #4
- Jul 2008
- Poestenkill, NY
- 764
01-24-2011, 04:56 PM #5Remember, some poor fool has to work on what you install someday, and it might even be you.
01-24-2011, 05:02 PM #6
See response to kevik about reverse return piping. Also no need for circuit setters as both circuits are identical footages nearly down to the inch. I didn't want to complicate it and add pressure drop when not necassary. There are PT ports on all 4 pipes of both circuits we checked pressure drop and flow is a spot on match. Thank you for responding.
01-24-2011, 05:04 PM #7
Is that diamond plate behind the controls?
01-24-2011, 05:10 PM #8
The propress tool has been one of the best investments ever. Looking back at all the jobs like this we used to do by soldering I can't believe all the time I'll never get back. I have never had a leaking problem other than human error such as pipe not in far enough or in crooked and snagged the oring even that only a couple times. I just hope the connections outlast me.
01-24-2011, 05:11 PM #9
01-24-2011, 08:34 PM #10
- Sep 2008
- 501
I know squat about geo but the piping sure looks purdy....nice touch with the diamond plate haven't seen that b4.
01-24-2011, 10:29 PM #11
Wow, I'm impressed with that!
01-25-2011, 02:04 PM #12
- Apr 2009
- Lancaster,PA
- 23
Very clean pipe work......Nice Job
01-25-2011, 02:27 PM #13
- Jul 2008
- Poestenkill, NY
- 764
Pretty clever - I like how you did that.
Depending on how long the circuits are (read- if they are very long and/or high head) - using the run or bull of the Tees won't effect flow in one circuit versus the other much anyhow. But, that being said, you thought about it and did the smart play by simply reversing the return path, so I'll just shut up. lol
