Results 1 to 6 of 6
    Apr 2005
    Farmingdale NJ
    I am installing a Trane highboy oil furnace. How much clearance from the top of the furnace do I need for the evap coil. I believe at least 4 inches.or the coil could melt.. is this true?
    Maine
    What does the install manual say?
    Apr 2003
    Eugene, Oregon
    Hopefully this is an upflow, most install manuals say 2" to combustibles, most coils have a plastic pan. So 4" would be safe. Alway's consult install instructions.
    Proud supporter of Springfield Millers and Oregon Ducks.
    Apr 2005
    I always go 6 inches to be on the safe side. Oil is so much more hotter than gas as we all know.Regards HH.
    Use a coil with a metal drain pan.. we always use them on oil with no problems
    I've installed A-coils no more than 4" from the top of the furnace and no problems to date. Heat exchanger is probably at least 2" below that, so 4" off the top of the furnace is plenty.
Comfortech365 Virtual Event
