Results 1 to 11 of 11
    Dec 2010
    WiFi thermostat requires external transformer
    I'd like to put in a WiFi thermostat for my weekend home so I can turn on the heat prior to my arrival. My schedule is erratic so a simple programmable one won't work.
    The Filtrete (Home Depot brand, made by 3M) says it requires "HVAC power (C-Wire) or an external transformer). I pulled the cover off the thermostat and it only had two wires so I guess I need the external transformer.
    So, my question to you pros, is, how big a job is this? Am I looking at a couple hundred or a grand? What does the external transformer look like? Will it be an eyesore on my wall?
    Thanks,
    Bob
    Tallahassee, FL
    Are you saying that Home Depot has a WIFI thermostat?
    How much is that thing?
    Dec 2010
    Tallahassee, FL
    Ok.
    Looks like a Rebranded RiteTemp thermostat.
    Whats funny is its not even UL listed.
    I dont think the transformer will be mounted on the wall -- unless you get the installer off gregslist.
    Most comanies could install this for 1-2 hours labor I would think.
    You just might have to endure some ridicule for the stat!
    Nov 2000
    Eastern PA
    Wow! Talk about so not being a DIY job. Many contractors would need to spend time figuring out the proper parameters for installing this.
    Not that it is not a great idea. Ecobee has had their WiFi capable stat out for several years now. It's just not something that HO's should be led to believe is an easy DIY job.
    Since there are many ways for a DIYer to accidentally damage existing controls and equipment transformers in the installation of this t-stat, I must recommend that it be professionally installed by an HVAC contractor.
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    Dec 2010
    Turns out it's not so hard
    They sell the proper transformer/adapter for $14.00 and it is properly coded to attach to the terminals. As long as the power is off, it seems easy. Luckily I have wall power just a few feet below the thermostat.
    http://store.radiothermostat.com/24V...sformer-PA.htm
    Nov 2000
    Eastern PA
    Quote Originally Posted by RVH View Post
    Good luck.
    Cincinnati, Oh
    Quote Originally Posted by RoBoTeq View Post
    Good luck.
    Really. We'll pray for you.
    The sad part is RVH...your way off.
    Call a pro. It'll be ALOT easier.
    Infact, I will tell you, that if you put that transformer on, the only thing your going to produce is smoke.
    "Just get it done son."
    Dad adjusted
    Nov 2000
    Eastern PA
    Quote Originally Posted by hvacvegas View Post
    Transformers don't produce smoke. They run off of smoke. And when you let the smoke out, they won't run any more.
    Mar 2010
    Cleveland Area
    What kind of equipment (manufacturer) do you have at your weekend house? Trane, Carrier, etc.?
    Jul 2009
    Edited by mod
    Only professional members of this site are allowed to give DIY advice, and even then it must be limited.
