Results 1 to 13 of 15
    Oct 2010
    trane techview /magnets
    Ive read here a south pole magnet is required for binding,does anyone know if the magnets that are present inside duct smoke detectors(for testing detectors)would work for techview binding?
    1. go to your favorite wholesaler
    2. get a free pocket screwdriver with the magnet on the end
    3. use for techview binding
    4. if it does not work, take needle nose plier out of your tool bag
    5. use needle nose pliers to remove magnet from pocket screwdriver
    6. turn magnet 180 degrees and re-insert magnet into pocket screwdriver
    7. return to step #3
    total cost: free
    ottawa canada
    Can I have a copy of the service bulletin on how to perform this procedure
    windy city
    Quote Originally Posted by graham View Post
    Cant gain access to Train site.
    \m/
    original member of the racoon brotherhood
    Jan 2005
    Houston TX
    I have it
    That would be Trane service bulletin, Trane TV-SB-OUR12-BR549
    Having sex is like playing cards, if you don't have a good partner, you better have a good hand. !!!!!!
    Top secret magnet!!!!!!!!
    true knowledge exists in knowing that you know nothing.
    Somewhere in the world.
    Cost for the screw driver $ 5.00
    Cost for picking up part and driving to customer $ 250.00
    Coming to this site to learn how to use it priceless !
    A mind is like a parachute. It doesn't work if it is not open.
    The best part of going to work is coming back home at the end of the day.
    Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all.
    ottawa canada
    Cant ..... I guess the line is busy
    Metro ATL
    Quote Originally Posted by Dilp172 View Post
    Only if you hold it in your left hand.
    Jun 2010
    Tampa, FL
    I was a long way from the van and didn't have my Trane screwdriver along. I used the magnet in the flap of my cell phone pouch. Lit up the LED just fine. You don't have to turn the magnet around in an ordinary magnetic screwdriver. Just pass it by the LED a bit farther up the handle.
    ottawa canada
    Yeah but dont forget if you dont point your tongue in the right direction as you swipe with the screwdriver it wont work and make sure your wearing your lucky fireproof underwear as well .
    Oct 2010
    Well i tried the smoke detector magnet and it worked,although it may have seemed like a dumb question i just didn't want to run to the supply house.
    ottawa canada
    If you turn the LLID upside down you can use the north pole magnet ...........
