Page 1 of 4 1234 LastLast
Results 1 to 13 of 46
    Dec 2010
    Why oversize the indoor coil?
    Just curious why a 4 ton coil was installed with my 3 ton heat pump. Installer said it was the only way the system would qualify for the tax rebate. I was hoping for more of a technical answer.
    Dec 2010
    Chillicothe, Ohio
    Larger coils = more surface area = greater heat transfer = higher efficiency
    Houston,Tx.
    Quote Originally Posted by chillitech71 View Post
    Maybe, but he has a HP and and that may not be true, I have "always" heard on a HP system, the coil and condenser should match tonnage wise.
    These Tax credit systems are sometimes really strange. We just installed a Ruud system, 3ton that required the 100,000 btu furnace with the Ruud coil, and a 75,000 furnace with the Aspen coil, go figure. In Ohio this might be a good thing, but in Texas, I am sure the furnace will short cycle.
    Dec 2010
    So should the air handler be sized for 3 tons (1200 cfm) or 4 tons (1600 cfm)?
    Dec 2010
    Chillicothe, Ohio
    I agree that the matchups are very screwy with the tax thing ! That's our wonderful Government at work, but as for oversizing the evap, it's common practice and recommended by many manufacturers. Our company installs more heat pumps than anything in the residential market. We are a Lennox dealer, and all of the higher efficient units (HP or AC) are matched up by Lennox with larger evaps than condensers. TXV's need to match the condenser though..
    And that was post #15 for me .. I can apply for pro now !!
    Cincinnati, Oh
    Basically.
    It's technically not an "oversized" coil, as some people think. If your looking for a piece of equitment that would have a seer rating of 16, then to accomplish this you need to find two pieces of equitment, that when paired, produce 16 seer.
    Your outdoor unit, when paired with your coil, produce your desired seer rating.
    If you wanted a lower seer rating, then you could pair a different outdoor unit, with a different coil, and get a lower seer.
    These ratings can be found on your manufacturers website.
    "Just get it done son."
    Dad adjusted
    Houston,Tx.
    Quote Originally Posted by Ellbaker View Post
    I guess not, read what I posted up yonder. ^
    The 100,000 is a 5-ton furnace.
    Jul 2010
    If you want the seer rating you have to "over size" the coil. That is the proper way to do it.
    Houston,Tx.
    Quote Originally Posted by tincup59 View Post
    I don't know about "proper" way, but it is the "only" way.
    Jun 2009
    Albuquerque NM
    The AH needs to be sized for the matched coil and condenser. And the tax credit for AC depends on what it's matched up with.
    Some contractors give bogus info to their customer WRT the tax credit. Then they find out later they don't qualify.
    Post model numbers for the condenser, coil, and air handler and we'll look up the AHRI match and tax credit info for you.
    My 2.5 ton condenser has a 3.5 ton coil, and qualified for the credit. My air handler (furnace) has a 4 ton blower. I could not have used a furnace with a 3 ton blower, unless it could do the 1400 CFM (some 3 ton blowers can) required for the 3.5 ton coil.
    Aug 2010
    Monroe County, PA
    If designed by the manufacturer to work together to accomplish a specific SEER or HSPF rating, I would still say they are a "matched" pair.
    To EllBaker's question about the appropriate CFM, I'm going to hazard a guess that setting the CFM to match the condenser's capacity is the way to go, regardless of size of the coil in the air handler (unless the coil is undersized I would assume). Regardless of indoor coil surface area, there is only so much "heat" to be extracted from the coils and too much air across them means each cubic foot absorbs less energy.
    But this is one where I am out of my league. Anyone know the physics behind this and whether it should be Condenser size or indoor coil size that should drive the CFM setting?
    Aug 2010
    Monroe County, PA
    Dang Gary - you type faster than I do, and your answer is better than mine!
    Jun 2009
    Albuquerque NM
    Quote Originally Posted by Tom Campbell View Post
    CFM should be set according to the manufacturer's specs in the product data or installation guides for the coil and condenser, for each air handler it's rated with. However, the ones I have seen are almost always rated at around 400 CFM/ton, for the coil size (tons). Sometimes this has to be adjusted for altitude though.
