Results 1 to 8 of 8
    Did a quick visual inspection of the blower and heat strips (I got 5 of them 24kw (5+5+5+5+4).
    What can I (Mr. Homeowner) do to test if all the strips (and what appear to be switches [black plastic circular]) are working OK and if all of them are coming on. Or is this job better left to HVAC folks. I know my way around a volt/ohm meter. I just need guidance on what I should/should-not be looking for.
    ALSO:
    I have a air leak somewhere in the return trunk near the furnace. I get this suction action if I close the door for the furnace room. As I close the door the air velocity increases at the door's edge. Prompting me to suspect the return is sucking air nearby instead of the return vents.
    I have seen a hand-held device that pumps smoke into the air. It is used to detect leaks and air currents. Can this thing be purchased at a RENO type store?
    Yea , that would be called a cigarette
    Mr Homeowner should call a qualified tech to test anything in an electric furnace- there has got to be a qualified person between Reno and Trukee somewhere
    Call a contractor, you don't want to see the sparks, or fire if you do some thing wrong.
    with 240 volts and 100 amps, you might just see Jesus.
    Huntsville,AL
    too complex to try & explain -- too many ways to get killed.
    Nov 2001
    east kansas
    Holy Crap man! I blow through quite a bit of things, except for electric frunaces. I've done lots. I remember the very first one I did. Welded my meter lead to the frunace.
    Homeowner now. Land owner in the near future. At the local cemetary.
    Thanks gents,
    Just a comment. I plan to live quite a few more years. When I asked if I could test anything, it was with the power "OFF". I would imagine there ain't much except for maybe the continuity. I have opened it before (blower clean & oil). The house panel breaker turned off is the first item of business "always".
    I would never dream of putting fingers, or anything for that matter, into that area with live juice. I have seen 120V make enough sparks to make me see the light.
    As "Billva" said, 240V/100A is enough to make a beautiful barbecue. I do not intend for me being the main course.
    My idea was to check the continuity on the banks to see if they are healthy. I assume that the simple fact that you get an OHM reading implies it is OK. My idea was to see what reading I should be reading.
    I agree with all of you. The furnace "live" is no place for an amateur. Too many things could/would go wrong.
    Ohming them out only tells half the story, you still wouldn't know if the sequencers are bringing them on.
