Results 1 to 13 of 14
    Oct 2009
    Mukwonago, WI
    automatically start a kitchen hood system
    What do you guys use? Captive Aire supplied a in-duct switch that closes at 85°. It's a little pricey, i was looking for a less expensive alternative.
    Any suggestions?
    Lake Worth, FL
    Not s.ure exactly what you're referring to but usually I see just a simple on/off switch. You might have a control that turns the system on and off based on temperatures from cooking equipment that only runs when equipment is on. That would save utility money that would more than pay for the expensive switch
    Jan 2011
    Russellville, Alabama
    Have you thought about using a line voltage thermostat - like Johnson Controls? Don't know if it would be cheaper than your switch, but will definitely work.
    Apr 2010
    N. IL
    look into Melink Intelli-Hood systems or something along those lines, they use temp sensor(s) and a set of optics and a vfd to control it. easy to use and install. offers great money savings too
    Albuquerque, NM
    The hoods should be turned on when the equipment is started for the day. What exactly are you trying to accomplish?
    Mark
    Oct 2009
    Mukwonago, WI
    Quote Originally Posted by maninblack View Post
    IMC 507.2.1.1 states Type I hood systems shall be designed and installed to automatically activate the exhaust fan whenever cooking operations occur. The activation of the exhaust fan shall occur through an interlock with the cooking appliances, by means of heat sensors or by means on other approved methods.
    Currently we get a vulcan cal-stat from Captive Aire that is installed in the grease duct and turns the system on when it reaches 85°. This item is a little pricey from Captive Aire and i'm looking for a more cost effective alternative. I'm just curious what other people use.
    Albuquerque, NM
    I would stick with what the manufacturer sells. That hood has a UL listing. I don't think NM goes by that code.
    Mark
    Des Moines, IA
    How bout heavy smoke and less than 85
    St Paul, minnesota
    Quote Originally Posted by Miller257 View Post
    here you can't use anything else unless you can prove it's ul listed for grease and high temp hoods. we had a couple of kitchen contractors install Honeywell remote bulb thermostats tied to relays. inspectors would not allow it.
    Dry as a bone Tucson
    Any suggestions?
    The Captiveaire hoods I have worked on run all the time due to pilot flames maintaining a nice warm temp under the hoods. What a stupid set up.
    What did you end up doing?
    John Proctor
    Watchman Nee
    St Paul, minnesota
    Hmm
    if you have the standard captive UL listed heat sensor system with PLC'S just reset the control to a higher temperature so that hood MUA EXH only come on when main burners are on. ( personally I set mine at 115 degrees)
    Sep 2011
    Maryland
    Quote Originally Posted by ACFIXR View Post
    The stat is adjustable
    Quote Originally Posted by Ovenguy View Post
    Thanks.............Now i can suggest that they be raised, 85 degrees is pretty low, the things run all of the time.
    John Proctor
    Watchman Nee
