Results 1 to 13 of 18
    hey guys. i am looking 2000 Btu/hr air conditioner. anyone here know where can i find one for under $500. let me know. Thanks
    North St Paul MN
    Menards, Home Depot, Lowes, Kmart, Sears, Want ads...
    I'd rather have a bottle in front of me, than a frontal lobotomy.
    i know about all these places but i cant find a AC less then 5000 btu. I need between 1500 btu to 2000 btu. no more.
    2000 BTU?? You won't even find a window shaker that small. Good luck. Probably have to be some specialty unit that will cost an arm & a leg.
    yah. it is costing me arm and leg. $2000 and sometimes more. I can make one myself but i dont know any companies that have all the parts i need.
    What is the application?
    If wall unit type is okay,do a search on PTAC's there are some compamys that build specialy models,they might do it for less.
    I am using it to cool a enclosure for PCs. As long as i can find a air conditioner with 1500~2000 btu, i will have someone rip it apart and put it back together for my design. i just need these parts and since HVAC is not my field, i dont know where to look. If i can get the individual components (compressor, evaporator, condensor and expansion valve) i can still make it work but my problem is that i dont know how to size all the components.Well lets see what happens.
    take a look at http://www.mrslim.com
    they have the inverter(variable) compressor.
    it will do a great job for a small computer room.
    if i recall correctly, the minium capacity is approx. 9000 btu's, but will go lower depending on the load with the inverter compressor.
    i beiieve the model # is mxz
    good luck.
    How about a high temp reach in evap and a high temp condensing unit? You better make sure it is sized right. Do not mix humidity with electronics.
    Jan 2005
    Seattle
    Talking Baby a/c
    I found one.And just the othere day!!!
    Aug 2001
    does it cool baby's?
    Toledo, Ohio, United States
    No Heat No Cool You need Action Fast
    North St Paul MN
    Testimonials from Jim and Tammy Fay Baker!...man, I wonder if anybody remembers THAT story!
