Air handler in attic
We just bought a new house and we have an old air handler in the attic. There is little to no insulation on the air handler itself. The ducts have minimal insulation. We are looking at replacing the whole unit and ducts.
We have an oil based boiler that feeds a hyrdonic heater in our air handler.
I've been looking at the Trane Hyperion which seems like a novel idea of constructing it like a refrigerator.
Any other good air handlers out there for the attic? I hate losing heat to the attic. We live in Boston area. Thanks.
All of the major brands would be about equal. I would try to find a space within the house to relocated it in order to minimize heat loss
If it has to be in the attic that airhandler seems to be a good idea. I have no experience first hand but the concept seems valid.
If it not mandatory in your area request R-8 insulated flex and mastic all joints, the contractor may do this as standard but ask about their sealing methods.
In addition to making sure the ducts are well insulated & sealed, you may want to consider laying the ducts at floor level (assuming flex duct, they will still need to be strapped, they should be as straight as possible with no sagging) & having additional insulation blown over them. (You will probably need to contact a separate insulation contractor for this work & coordinate between the contractors a little bit to make sure everyone understands the plan.) You can achieve much higher insulation levels by doing this than by duct R-values alone. I also recommend seeing if your local utility/utilities have any rebates for the duct seal and/or the insulation; you may very well be able to save some bucks on the work.
I really should have mentioned that laying the ducts on the floor may not be possible in your attic. This depends on the layout of your attic, the location of the equipment and the location of the trusses.
Redefine your thermal boundary so it includes your hvac equipment. You'll be able to get smaller, higher efficiency equipment that is much quieter and more comfortable.
- You may not post replies
- You may not edit your posts
Forum Rules
