Page 4 of 113 FirstFirst 12345678910111454104 ... LastLast
Results 40 to 52 of 1468
  1. #40
    Jan 2011
    Spokane, WA
    Quote Originally Posted by Tlaloc289 View Post
    Well the system is actually a 10ton unit it has two 5 tons and both of the coils go to one airhandler. the top unit is completely plugged even the fan had a nice layer of dirt. the hole is the "custom made" filter rack for the system. its on the return line just before it goes to the coil.
    I thought you were saying a whole in the line set, like a leak. Now I see, said the blind man.
  2. #41
    Dec 2010
    Wa State
    Quote Originally Posted by supertek65 View Post
    65 degrees????????????????
    yeah 65 degrees. its a locked and monitored computer room. if you shut the AC units the temp rises to 80 within 30 minutes. That why they have the heat gun. they were tearing the panels off using the heat gun and warm water to defrost the unit in 10-15 minutes
  3. #42
    Dec 2010
    Wa State
    Quote Originally Posted by Klay View Post
    the hole is the 4'' by 48'' double filter coveron the sheetmetal
  4. #43
    Dec 2010
    Wa State
    i grabbed my flash light and i cant see through the indoor coil. ice is gone. i moved the location of the freeze stat so its actually insidethe fins and not loosely flapping on the coil. i guess it would take alot for the stat to measure freezing temps if its just measuring return air temp.hahaha
  5. #44
    Dec 2010
    Wa State
    Wow. the coil is completely closed. i even tried putting a metal kabob stick trough the coil but couldnt make it past the first layer of dirt.
  6. #45
    Jan 2011
    Spokane, WA
    Question
    I was curious about this, (I'm new to the field so please excercise some patience) I hadn't heard anyone mention it, or don't recall any talk of a coil so dirty, it would have to be replaced. Having been under these conditions for so long, is the coil still salvageable? What kind of time frame is your co. allowing you to fight with this?
  7. #46
    Dec 2010
    Wa State
    Im a service Tech but the place im working on hired me as a maintenance guy. they figured it was cheaper to hire and keep a service tech on staff than call someone every week. They want me to save the coil. so I will do my best, they have alot of these spray coil cleaner bottles and all the time in the world. ill post my results later on
  8. #47
    Use a foaming coil cleaner and compressed air or nitrogen.
    You *should* be able to get that cleaned well enough to work.
    If that fails, a pressure washer can also be used, CAREFULLY!
  9. #48
    anything can be cleaned!!!!!!!!!!!!!!!
    but for us at $150 an hour it would have been replaced a long time ago!!!!!!!!
  10. #49
    New jersey
    Very new to this but would like to hear the outcome. My teacher talked about this type of situation. Never do severe. Want to know what I would have to do in such a situation.
  11. #50
    In a machine room
    That's all???
    We should probably be a little careful about prices in an open forum.
  12. #51
    that is just a rounded number!!!!!!!!!!!!
    you will have to guess if i rounded up or down or to the nearest 10 , 50, or 100??????????????????????????????????????????????? ?
    That's all???
  13. #52
    In a machine room
    No problem!! I thought it was a general number!!!
Tags for this Thread
