Results 1 to 7 of 7
Thread: Johnson Null Modem USB
03-29-2005, 05:37 PM #1
I connect to the Facilitator / N30 with a null modem cable
I then run ProComm Plus
Very routine,No problems
New computer has no RS-232 ports
It has the following portsI
A USB 2.0 and the new small USB connections
an Ethernet / RJ-45 female port
I have bad luck with the USB / RS-232 adaptor
(computer cant find the device)
Is there:
1) An Ethernet to RS-232 adaptor cable
2) Can I use a patch cable to connect facilitator N-30
3) Can I run Pro Comm with the USB/ RS-232 adaptor
Thank You
03-29-2005, 05:59 PM #2
Banned
- Feb 2005
- 1,475
Does your USB to serial adapter allow you to number it as a port low enopugh for your program to use it. ?
If it does you should be able to assign it a port number that your program wants to see,I am not that familiar with pro comm but I have had problems where a dos program would not recognize it even as a port number , I picked up a program called Virtual PC, and used it for the old DOS programs, it will allow a USB to serial connection, numbered as a serial port to be used by a DOS program.
Don't know if this is pertinent,
I use a Belkin F5U103 USB to serial adapter, then run A virtual drive with DOS as the OS and choose the number port that it is connected to, this program will also take care of any display issues that some DOS programs have on newer computers.
looks like this model is no longer available,which one do you have ?
[Edited by fat eddy on 03-29-2005 at 06:16 PM]
03-29-2005, 08:11 PM #3
Does your computer have a pcmcia card slot? most people have better luck with pcmcia to RS232 cards than with the USB ones.
"Profit is not the legitimate purpose of business. The legitimate purpose of business is to provide a product or service that people need and do it so well that it's profitable."
James Rouse
03-29-2005, 08:53 PM #4
Banned
- Feb 2005
- 1,475
I'm thinking his program doesn't recognize it, i'm not sure if that is what he means or just that his computer won't. Some old programs won't recognize it even if the computer does, they just don't see the USB port.
03-30-2005, 01:27 AM #5
- Jan 2005
- 35
S squared innovations inc. makes a USB to N2/rs-232 adapter, model number s2usb485 , http://www.s2innovations.com , its pretty nice, just install the drivers and assign the device to com port 1 or 2. I've been using it for n2 communication almost exclusively for the past couple of months, but am not sure about the rs-232 comm... may or may not be null modem... Hope this is useful...
03-30-2005, 06:41 PM #6
can I make a cross over cable(Null Modem)
Ethernet (RJ 45) to RS232
The rs-232 only uses two wires
03-30-2005, 08:12 PM #7
Unfortuneately there is no stand alone cable
I have to use a serial /usb adaptor , and
install a device driver
Thank You
