Thread: Old SEER rating
    Wisconsin
    I have a 1989 Lennox HS19. Is there any way of determining the SEER?
    jim
    Apr 2004
    Not unless you have the complet model number and the indoor equipment model numbers and then one of the gurus in here might help.
    Odds are its around 9
    SW Wisconsin
    The unit is not apt to be operating at its rated SEER and Btu/hr level, therefore, the SEER is rather irrelvant.
    When a typical HVAC contractor quotes the efficiency of the Air Conditioning equipment SEER & Btu/hr and leads you to believe the new equipment will automatically deliver that efficiency & Btu/hr, think again.
    Typically, installed equipment only operates at 55% to 70% of rated capacity.
    It’s important to understand that "equipment ratings are only the potential efficiency of that component of the system under perfect conditions." Over half of the system’s efficiency depends on the duct system and the field-installation.
    http://www.udarrell.com/aircondition...e-airflow.html
    burlington county n.j.
    10 - 11.5 depending on unit and coil match. need model #s for exact rating.
