    I have a german made Ziehl Abegg 104370 02061222 centrifugal duct fan (motorized impeller).
    Being Europen made, the color code is different than U.S.
    So far I have found:
    yellow with green stripe = ground
    blue = neutral
    brown = 1st phase conductor
    black = 2nd phase conductor
    The fan motor is A.C. single phase 115v 50HZ / 220v with capacitor and thermostat.
    where can I go to find schematics for this unit?
    [Edited by jibov on 03-28-2005 at 06:55 PM]
    SE Michigan
    Please read sight rules.
    “Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery.”
    Aug 2001
    are you telling us this or are you asking ?
    50hz 115 volt, and you want to run it on 60hz.
    Where did you get it from, they should have the diagram you need.
