Results 1 to 8 of 8
    Jul 2010
    Oak Creek,WI
    Howling Zone System
    I recently installed a zone system for a furnace. The problem I am having is there is a hollowing sound coming from the 2 zones that are closed that the customer can hear in the night.Bypass damper I thought would do the trick. No such luck! The duct work is sized correctly to handle the amount of CFM's. Any ideas. Now I will say the bypass damper fully opened does remove the sound but because there is so much air being dumped back into the return, the limit is tripped. Any suggestions?
    Last edited by jonsbears; 01-16-2011 at 09:43 AM. Reason: Title needed better topic name
    Arizona
    Couple of thoughts, are you using a LAT ( leaving air temperature sensor)?
    How many zones are on the system?
    Are they of about equal size( Load)?
    Is this multi stage equipment?
    What brand of zoning system?
    Make your expertise uniquely valuable.
    Make your influence uniquely far-reaching.
    Jul 2010
    Oak Creek,WI
    No, I am not using a LAT,There a 3 zones, and the zones are about equal size, it is a single stage furnace. I can't think of the manufacturer of the system. I can picture it but can't remember the name! It may be quiet zone
    Arizona
    Quote Originally Posted by jonsbears View Post
    I would start by installing a LAT, that way your cycling the burner on it (at safe temps) not the limit. I'm surprised thats not part of there zone system.
    Definitely should have a LAT. If you are using the furnace limit to do it, it will soon stick open leaving the HO without heat.
    Besides the bypass, you can have a dump zone, runs that aren't on a zone damper.
    Appears to be oversized equipment and when a good chunk of the ductwork is taken away, is grossly hurting.
    Jul 2010
    Oak Creek,WI
    Sorry guys I did install a LAT in the plenum! What about taking out the bypass damper and putting in supply grill in place of it?
    Arizona
    You need to get your post count up, apply for Pro and ask for help there. This sounds like DIY questions and there not allowed, sorry.
    Jul 2010
    Oak Creek,WI
    I am new a this, but I am not a DIY.I graduated from my tech college in this field and work for a mechanical company in WI. I'm living the dream and love what I do. How do I get pro status. I usually talk to my service techs but getting other peoples advice or knowledge is helpful.
