Results 1 to 13 of 15
    Dec 2003
    I am trying to enable a piece of equipment through a dry bulb temp and %rh... is there an equation that can take the db and rh and convert it to a wet bulb?? thanks, adam.
    Still learning....
    I am sure there must be an"equation"for this but I sure dont know it...anyway you might want to look at this thread:
    RH and TEMP conversion chart---- by nicholasa---IAQ section
    Minnesota
    Do you read the Basic programming language, at least a little?
    If so, you should find the math formulas you want here:
    http://f6.grp.yahoofs.com/v1/UM1FQql...AirPsychro.bas
    It's a Basic program I wrote that'll accept DB, RH, and Altitude inputs, then give you 6 other values as a result. Wet Bulb, Enthalpy, etc.
    Use it as you wish.
    Even if you don't understand Basic, it's not hard to follow the code and find the math routines. If yah know basic math, you can understand the formulas.
    If the link doesn't work for you, let me know and I'll try some other way of getting the text of the file to you.
    Dec 2003
    thanks for the input osiyo, i'm having some trouble w/ the link, can you help at all?
    Still learning....
    get a sling psycrometer. It has WB DB and RH
    Saddle Up!
    Minnesota
    Okay, try this. Go to the below site.
    http://groups.yahoo.com/group/rapidq/
    You'll have to subscribe to the group to look into the "Files" section. A painless process and costs nothing. They just ask for a valid email address. I've been a subscriber to various Yahoo Groups for years, and near as I can tell they've never passed around my email addy. Nor will they send yah annoying mail unless you allow it.
    Anyway, subscribe. Takes 30 seconds. Then look into the "Files" section. And you'll see "airpsychro.bas". It's a simple text file. You don't need any special program to view, download, or edit it.
    I'd just paste it here, however I'm not sure this site would like an 18k text file pasted into their edit box. Plus it'd word wrap in this site's edit box, which would make it hard to read.
    If that doesn't work, say so. And if you have an available email addy I'll email it direct.
    Minnesota
    True. But then, he asked for the equations. So I presumed he might be writing a program.
    If he just wants to do the conversion manually, he could also use a standard psychrometric chart.
    Yes,I was afraid you control guys were talking about something else...
    here ya go:
    RH=100e(Tw-Td/28.116)-17.4935(Td-Tw)e-Td/28.116
    RH is in percent.Td is dry bulb in F.Tw is wet bulb in F.
    The symbol e refers to the exponential function.The exponential function is taken to the power represented by the number above the symbol.(The function of e is the usual one used where 2.71828 is the value of e)
    The formula for grains of water per pound of dry air is:
    grain/pound=.09065RHeTd/28.116
    Now remember that I could only copy that from the book to here in "keyboard style".I think you can decipher it though.
    Agross, are you programming, if you are I have just the thing
    Here is a good one:
    X = 273.16 / ((DryBulb - 32) / 1.8 + 273.16)
    X = -10.7959 * (1 - X) - (2.1836 * ln(X)) + 2.2196
    X = 29.92 * (1 / exp(2.3026 * X))
    X = RH * X / 100
    X = 0.622 * X / (29.92 - X)
    Enthalpy = (0.24 + (0.444 * X)) * DryBulb + (1061 * X)
    Dec 2003
    Yes, I'm trying to... we have an old plate and frame that was used for free cooling... apparently when they switched over control systems (Barber-Coleman to Siemens) the new actuators/programming were not included for it, only the chillers and cooling tower. This was well before I started working there so I really don't know all the specifics. Anyway, we had to replace an isolation valve on one of the chillers so we manually switched over to the plate and frame and it worked beautifully, chilled water temps held better than expected. My new goal is to convince my boss that we should use it when OAT & RH are favorable. In order to do so, he wants a sequence of operations and a program. This particular chilled water system supports some critical equipment so there is no room for error. I did some research on plate and frame free cooling I found out that you can only use it when WB is 10F less than desired chilled water temp; because we only have OAT & RH sensors, I need to find a way to calculate the WB. Thanks for all the help, Adam.
    Still learning....
    Minnesota
    Originally posted by schoolguy
    Here is a good one:
    X = RH * X / 100
    Not bad, the algorithm gives a pretty decent approximation. I tested it against a known mathematical model and yours gives good results in simpler form. Doesn't correct for altitude, etc but the answers are perfectly useable for ordinary HVAC work.
    However, you're calculating enthalphy. Original poster requested Wet Bulb.
    I see that as one works the math, by line #4 above, you
    extract the partial vapor pressure. That's the X=RH*X/100
    line, in case line counting gets confusing due to
    reformatting of lines on your screen.
    Now, there is no such thing as a math formula that will give
    one the EXACT, one and only answer, for Wet Bulb
    calculations. The only thing math can do is approximate.
    And as to how close a math algorithm is to the reality of a
    measured WBT, depends on how complicated one wishes to get
    with your math.
    If one is trying to stay fairly simple, once one has worked
    out the first 4 lines above, you've arrived at Partial Vapor
    Pressure (close enough for most HVAC purposes)for the given
    DBT and RH.
    Using the PVP, find approx Dew Point.
    nn=pvp*0.491154
    y = LOG(nn)
    IF pvp < 0.18036 THEN
    dp = 90.12 + (26.142 * y) + (0.8927 * y * y)
    ELSE
    dp = 100.45 + (33.193 * y) + (2.319 * y * y)
    dp = dp + 0.17074*(y^3)+1.2063*((pvp*0.491154)^0.1984)
    END IF
    (Watch out for line wrap)
    From here, one can keep it simple and use the "1/3 Rule"
    that metrologists often use to approximate WBT. Which gives
    a fairly decent result under most operating conditions for
    the equipment the original poster mentions.
    Under the 1/3 Rule one figures out the Dew Point Depression (DPD), which is the difference between Dry Bulb and Dew Point. Then divide DPD by 3. And subtract that result from Dry Bulb.
    To be safe, I'd add 1.0 to the WBT answer before doing the
    subtraction to determine if Desired Coil Temp minus WBT >= 10.
    Other than that. One just about has to resort to using an
    iterative mathematical model to extract a more accurate
    answer. Which is what those electronic meters that read DBT
    and RH then calculate WBT when yah push a button do. And
    what I used in the Basic language programming example I
    pointed to in my original response. That example uses an
    algorithm published by ASHRAE, that was tested against
    actual measured values and shown to be accurate enough for
    HVAC design purposes.
    Now, if the original poster is looking for a nice, simple X=
    Y*Z type formula. I'm afraid he's SOL. There is no such
    simple mathematical formula possible that'll give any sort
    of meaningful and useful answer.
    Minnesota
    I'll give it a try to post the text version of the Basic code I mentioned before. It's written in RapidQ Basic, but that version is generic enough so that the code should be easily converted to most any programming language. I know it took me very little time to convert it from the original VBA to Java Script, and equally little time to convert it to RapidQ. Originally I'd written it in old DOS QBasic, but have lost the original source code somewhere among a pile of old, archived code on CDs I've got piled up. Which I have intended to catalog, for years, but have never seemed to get around to it. :-)
    Watch out for line wrap ....
    'Just a little routine to calculate the Psychrometric properties
    'of air given 3 known conditions.
    'Given Dry Bulb Temperature, Relative Humidity, and Altitude of a
    'location. The routine calculates 8 other properties of the air
    'sample. Results can be saved. Mostly useful to HVAC types (Heating
    'Ventilation and Air Condicitoning), engineers, science students, etc.
    'I'd originally written this in another programming language but a
    'friend, who is learning to program in RapidQ asked me for an
    'an example program in RapidQ that used some simple functions he was
    'trying to grasp how to do. ie How to implement math functions, simple
    'input boxes, buttons, etc. And how to save a simple text file.
    'I'm no real programmer, nor expert by any means with RapidQ, so nothing
    'here for any experienced programmer to find useful.
    'However, I thought perhaps a beginner might find some use in my simple
    'style and techniques. Or perhaps someone will find the math functions
    'for deriving the various other properties of air from the given 3 to
    'be of use.
    'Free for anyone to use as he or she sees fit.
    'Bob G - Osiyo53@yahoo.com
    $Include "Rapidq.inc"
    DECLARE sub calculate_drha
    DECLARE Sub Closemain
    DECLARE Sub Dummyproc
    DECLARE Sub reset_form
    DECLARE Sub save_file
    DIM inout_label_Font AS Qfont
    inout_label_Font.Name = "MS Sans Serif"
    inout_label_Font.Size = 8
    inout_label_Font.Color = clWindowText
    inout_label_Font.AddStyles(fsBold,fsUnderLine)
    DIM Label1_Font AS QFont
    Label1_Font.Name = "MS Sans Serif"
    Label1_Font.Size = 8
    Label1_Font.Color = clWindowText
    Label1_Font.AddStyles(fsBold)
    DIM SaveDialog AS QSAVEDIALOG
    SaveDialog.Filter = "Text Files(*.TXT)|*.TXT|All Files(*.*)|*.*"
    SaveDialog.FilterIndex = 1 '' Use "Text Files" as default
    DIM file1 AS QFILESTREAM
    DIM a1 AS DOUBLE
    DIM a2 AS DOUBLE
    DIM a3 AS DOUBLE
    DIM a4 AS DOUBLE
    DIM a5 AS DOUBLE
    DIM a6 AS DOUBLE
    DIM acc AS DOUBLE
    DIM atm AS DOUBLE
    DIM b1 AS DOUBLE
    DIM b2 AS DOUBLE
    DIM b3 AS DOUBLE
    DIM b4 AS DOUBLE
    DIM db AS DOUBLE
    DIM dp AS DOUBLE
    DIM dx AS DOUBLE
    DIM elev AS DOUBLE
    DIM fmid AS DOUBLE
    DIM h AS DOUBLE
    DIM j AS DOUBLE
    DIM nn AS DOUBLE
    DIM p1 AS DOUBLE
    DIM p2 AS DOUBLE
    DIM p3 AS DOUBLE
    DIM p4 AS DOUBLE
    DIM psat AS DOUBLE
    DIM pvp AS DOUBLE
    DIM pvs AS DOUBLE
    DIM rh AS DOUBLE
    DIM rhpercent AS DOUBLE
    DIM rtb AS DOUBLE
    DIM savename AS STRING
    DIM ta AS DOUBLE
    DIM v AS DOUBLE
    DIM vp AS DOUBLE
    DIM w AS DOUBLE
    DIM wb AS DOUBLE
    DIM wh AS DOUBLE
    DIM ws AS DOUBLE
    DIM wsat AS DOUBLE
    DIM wstar AS DOUBLE
    DIM wtemp AS DOUBLE
    DIM xmid AS DOUBLE
    DIM y AS DOUBLE
    DIM z AS DOUBLE
    ' Calculate the Logarithm of a number to the base 10
    FUNCTION log10(number AS DOUBLE)AS DOUBLE
    log10 = Log(number) / Log(10#)
    END FUNCTION
    ' Calculate Atmospheric pressure given elevation
    FUNCTION psychro_atm(elev AS DOUBLE)AS DOUBLE
    Dim el(21)AS DOUBLE, press(21)AS DOUBLE
    'Altitude Press.
    el(1) = -1000: press(1) = 31.02
    el(2) = -500: press(2) = 30.47
    el(3) = 0: press(3) = 29.921
    el(4) = 500: press(4) = 29.38
    el(5) = 1000: press(5) = 28.86
    el(6) = 2000: press(6) = 27.82
    el(7) = 3000: press(7) = 26.82
    el(8) = 4000: press(8) = 25.82
    el(9) = 5000: press(9) = 24.9
    el(10) = 6000: press(10) = 23.98
    el(11) = 7000: press(11) = 23.09
    el(12) = 8000: press(12) = 22.22
    el(13) = 9000: press(13) = 21.39
    el(14) = 10000: press(14) = 20.48
    el(15) = 15000: press(15) = 16.89
    el(16) = 20000: press(16) = 13.76
    el(17) = 30000: press(17) = 8.9
    el(18) = 40000: press(18) = 5.56
    el(19) = 50000: press(19) = 3.44
    el(20) = 60000: press(20) = 2.14
    i = 1
    WHILE elev > el(i)
    i = i + 1
    WEND
    psychro_atm = press(i)
    END FUNCTION
    ' Calculate vapor pressure at saturation given dry bulb temp
    FUNCTION psychro_pvs(temp AS DOUBLE)AS DOUBLE
    a1 = -7.90298
    a2 = 5.02808
    a3 = -0.00000013816
    a4 = 11.344
    a5 = 0.0081328
    a6 = -3.49149
    b1 = -9.09718
    b2 = -3.56654
    b3 = 0.876793
    b4 = 0.0060273
    ta = (temp + 459.688) / 1.8
    IF ta > 273.16 THEN
    z = 373.16 / ta
    p1 = (z - 1) * a1
    p2 = log10(z) * a2
    p3 = ((10 ^ ((1 - (1 / z)) * a4)) - 1) * a3
    p4 = ((10 ^ (a6 * (z - 1))) - 1) * a5
    ELSE
    z = 273.16 / ta
    p1 = b1 * (z - 1)
    p2 = b2 * log10(z)
    p3 = b3 * (1 - (1 / z))
    p4 = log10(b4)
    END IF
    psychro_pvs = 29.921 * (10 ^ (p1 + p2 + p3 + p4))
    END FUNCTION
    ' Calculate Humidity Ratio given dry bulb temp, relative humidity, and elevation
    FUNCTION psychro_wrh(db AS DOUBLE, rh AS DOUBLE, atm AS DOUBLE)AS DOUBLE
    wsat = psychro_pvs(db)
    wtemp = 0.62198 * (wsat / (atm - wsat))
    psychro_wrh = rh * wtemp
    END FUNCTION
    'Calculate Enthalpy given dry bulb temp and Humidity Ratio
    FUNCTION psychro_h_w(db AS DOUBLE, w AS DOUBLE)AS DOUBLE
    psychro_h_w = (db * 0.24) + (1061 + (0.444 * db))* w
    END FUNCTION
    'Calculate dew point temp. given Vapor Pressure
    FUNCTION psychro_dp(pvp AS DOUBLE) AS DOUBLE
    nn=pvp*0.491154
    y = LOG(nn)
    psychro_dp = 90.12 + (26.142 * y) + (0.8927 * y * y)
    ELSE
    psychro_dp = 100.45 + (33.193 * y) + (2.319 * y * y) + 0.17074*(y^3)+1.2063*((pvp*0.491154)^0.1984)
    END IF
    END FUNCTION
    'Calculate Humidity Ratio given dry bulb temp and pressure
    FUNCTION psychro_w_pvp(pair AS DOUBLE, pvp AS DOUBLE) AS DOUBLE
    psychro_w_pvp = 0.622 * pvp / pair
    END FUNCTION
    ' Calculate Vapor Pressure given dry bulb temp, wet bulb temp, and pressure
    FUNCTION psychro_pv1(db AS DOUBLE, wb AS DOUBLE, atm AS DOUBLE) AS DOUBLE
    pvp = psychro_pvs(wb)
    ws = (pvp / (atm - pvp)) * 0.62198
    IF wb <= 32 THEN
    wh=((1219.98+0.44*db-0.49*wb)*ws-0.24*(db-wb))/(1219.98+0.44*db-0.49*wb)
    psychro_pv1 = atm * (wh / (0.62198 + wh))
    ELSE
    wh=((1093-0.556*wb)*ws-0.24*(db-wb))/(1093+0.444*db-wb)
    END IF
    END FUNCTION
    'Calculate Humidity Ratio given dry bulb temp, wet bulb temp, and pressure
    FUNCTION psychro_w(db AS DOUBLE, wb AS DOUBLE, atm AS DOUBLE) AS DOUBLE
    vp = psychro_pv1(db, wb, atm)
    psychro_w = 0.622 * vp / (atm - vp)
    END FUNCTION
    'Computes wet-bulb temperature iteratively, dry bulb, dew point
    'enthalpy and atm pressure using Bisection method.
    FUNCTION wet_bulb(db AS DOUBLE,dp AS DOUBLE,h AS DOUBLE,atm AS DOUBLE)AS DOUBLE
    j=0
    acc=0.0001
    rtb=dp
    dx=db-dp
    WHILE j<40
    j=j+1
    dx=dx*0.5
    xmid=rtb+dx
    psat=psychro_pvs(xmid)
    wstar=psychro_w_pvp(atm-psat, psat)
    fmid=psychro_h_w(xmid, wstar)
    IF ((h-fmid)>0.0)THEN
    rtb=xmid
    END IF
    IF ABS(dx)<acc THEN
    EXIT WHILE
    END IF
    WEND
    wet_bulb=rtb
    wb=rtb
    END FUNCTION
    'Calculate Specific Volume given dry bulb temp, wet bulb temp, and pressure
    FUNCTION psychro_v(db AS DOUBLE, wb AS DOUBLE, atm AS DOUBLE)AS DOUBLE
    psychro_v = ((0.754 * (db + 459.7)* (1 + (7000 * psychro_w(db, wb, atm) / 4360))) / atm)
    END FUNCTION
    CREATE MainForm AS QForm
    Caption = "Bob G's (Osiyo) Free Software"
    Top = 129
    Left = 203
    Width = 460
    Height = 343
    Center
    Wndproc=Dummyproc
    Onclose=Closemain
    END CREATE
    CREATE main_label AS QLabel
    Parent = MainForm
    Top = 3
    Left = 93
    Width = 32
    Height = 13
    Caption = "Calculate Psychrometric Properties of Air"
    Color = &hC0C0C0
    Font = Label1_Font
    AutoSize = False
    END CREATE
    CREATE db_label AS QLabel
    Parent = MainForm
    Top = 51
    Left = 22
    Width = 32
    Height = 13
    Caption = "Dry Bulb Temp (F) : "
    Color = &hC0C0C0
    Font = Label1_Font
    AutoSize = False
    END CREATE
    CREATE rh_label AS QLabel
    Parent = MainForm
    Top = 75
    Left = 5
    Width = 109
    Height = 13
    Caption = "Relative Humidity (%) : "
    Color = &hC0C0C0
    Font = Label1_Font
    AutoSize = False
    END CREATE
    CREATE elev_label AS QLabel
    Parent = MainForm
    Top = 98
    Left = 7
    Width = 32
    Height = 13
    Caption = "Elev Above Sea (FT) : "
    Color = &hC0C0C0
    Font = Label1_Font
    AutoSize = False
    END CREATE
    CREATE input_label AS QLabel
    Parent = MainForm
    Top = 30
    Left = 51
    Width = 32
    Height = 13
    Caption = "INPUTS"
    Color = &hC0C0C0
    Font = inout_label_Font
    AutoSize = False
    END CREATE
    CREATE calc_btn AS QButton
    Parent = MainForm
    Top = 72
    Left = 238
    Width = 75
    Height = 25
    Caption = "CALCULATE"
    OnClick = calculate_drha
    END CREATE
    CREATE reset_btn AS QButton
    Parent = MainForm
    Top = 72
    Left = 358
    Width = 75
    Height = 25
    Caption = "RESET"
    OnClick = reset_form
    END CREATE
    CREATE db_edit AS QEdit
    Parent = MainForm
    Top = 48
    Left = 136
    Width = 49
    Height = 21
    Text = "70.0"
    Color = &hFFFFFF
    MaxLength = 5
    AutoSize = False
    END CREATE
    CREATE rh_edit AS QEdit
    Parent = MainForm
    Top = 72
    Left = 136
    Width = 49
    Height = 21
    Text = "50.0"
    Color = &hFFFFFF
    MaxLength = 5
    END CREATE
    CREATE elev_edit AS QEdit
    Parent = MainForm
    Top = 96
    Left = 135
    Width = 49
    Height = 21
    Text = "1000"
    Color = &hFFFFFF
    MaxLength = 6
    END CREATE
    CREATE output_label AS QLabel
    Parent = MainForm
    Top = 129
    Left = 182
    Width = 32
    Height = 13
    Caption = "OUTPUTS"
    Color = &hC0C0C0
    AutoSize = False
    END CREATE
    CREATE atm_label AS QLabel
    Parent = MainForm
    Top = 154
    Left = 18
    Width = 32
    Height = 13
    Caption = "Atmospheric Press (in.Hg) : "
    Color = &hC0C0C0
    Font = Label1_Font
    AutoSize = False
    END CREATE
    CREATE svp_label AS QLabel
    Parent = MainForm
    Top = 179
    Left = 6
    Width = 32
    Height = 13
    Caption = "Saturated Vap Press (in.Hg) : "
    Color = &hC0C0C0
    Font = Label1_Font
    AutoSize = False
    END CREATE
    CREATE pvp_label AS QLabel
    Parent = MainForm
    Top = 202
    Left = 25
    Width = 32
    Height = 13
    Caption = "Partial Vap Press (in.Hg) : "
    Color = &hC0C0C0
    Font = Label1_Font
    AutoSize = False
    END CREATE
    CREATE hr_label AS QLabel
    Parent = MainForm
    Top = 226
    Left = 44
    Width = 32
    Height = 13
    Caption = "Humidity Ratio (lb/lb) : "
    Color = &hC0C0C0
    Font = Label1_Font
    AutoSize = False
    END CREATE
    CREATE atm_edit AS QEdit
    Parent = MainForm
    Top = 150
    Left = 179
    Width = 49
    Height = 21
    Text = "0.0"
    Color = &hFFFFFF
    MaxLength = 7
    AutoSize = False
    ReadOnly = True
    END CREATE
    CREATE svp_edit AS QEdit
    Parent = MainForm
    Top = 174
    Left = 179
    Width = 49
    Height = 21
    Text = "0.0"
    Color = &hFFFFFF
    MaxLength = 7
    ReadOnly = True
    AutoSize = False
    END CREATE
    CREATE pvp_edit AS QEdit
    Parent = MainForm
    Top = 199
    Left = 179
    Width = 49
    Height = 21
    Text = "0.0"
    Color = &hFFFFFF
    MaxLength = 7
    ReadOnly = True
    AutoSize = False
    END CREATE
    CREATE hr_edit AS QEdit
    Parent = MainForm
    Top = 223
    Left = 178
    Width = 49
    Height = 21
    Text = "0.0"
    Color = &hFFFFFF
    MaxLength = 7
    AutoSize = False
    ReadOnly = True
    END CREATE
    CREATE svol_label AS QLabel
    Parent = MainForm
    Top = 154
    Left = 250
    Width = 32
    Height = 13
    Caption = "Specific Vol (cuft/lb) : "
    Color = &hC0C0C0
    Font = Label1_Font
    AutoSize = False
    END CREATE
    CREATE dp_label AS QLabel
    Parent = MainForm
    Top = 179
    Left = 291
    Width = 32
    Height = 13
    Caption = "Dew Point (F) : "
    Color = &hC0C0C0
    Font = Label1_Font
    AutoSize = False
    END CREATE
    CREATE wb_label AS QLabel
    Parent = MainForm
    Top = 202
    Left = 297
    Width = 32
    Height = 13
    Caption = "Wet Bulb (F) : "
    Color = &hC0C0C0
    Font = Label1_Font
    AutoSize = False
    END CREATE
    CREATE ent_label AS QLabel
    Parent = MainForm
    Top = 227
    Left = 266
    Width = 32
    Height = 13
    Caption = "Enthalpy (BTU/lb) : "
    Color = &hC0C0C0
    Font = Label1_Font
    END CREATE
    CREATE svol_edit AS QEdit
    Parent = MainForm
    Top = 150
    Left = 383
    Width = 49
    Height = 21
    Text = "0.0"
    Color = &hFFFFFF
    MaxLength = 7
    AutoSize = False
    ReadOnly = True
    END CREATE
    CREATE dp_edit AS QEdit
    Parent = MainForm
    Top = 175
    Left = 382
    Width = 49
    Height = 21
    Text = "0.0"
    Color = &hFFFFFF
    MaxLength = 7
    AutoSize = False
    ReadOnly = True
    END CREATE
    CREATE wb_edit AS QEdit
    Parent = MainForm
    Top = 200
    Left = 382
    Width = 49
    Height = 21
    Text = "0.0"
    Color = &hFFFFFF
    MaxLength = 7
    AutoSize = False
    ReadOnly = True
    END CREATE
    CREATE ent_edit AS QEdit
    Parent = MainForm
    Top = 225
    Left = 381
    Width = 49
    Height = 21
    Text = "0.0"
    Color = &hFFFFFF
    MaxLength = 7
    AutoSize = False
    ReadOnly = True
    END CREATE
    CREATE file_btn AS QButton
    Parent = MainForm
    Top = 264
    Left = 176
    Width = 75
    Height = 25
    Caption = "Save to File"
    OnClick = save_file
    END CREATE
    MainForm.ShowModal
    'Compute other properties given Dry Bulb Temp.,Relative Humidity and Altitude.
    SUB calculate_drha
    db=VAL(db_edit.Text)
    elev=VAL(elev_edit.Text)
    rhpercent=VAL(rh_edit.Text)
    rh=rhpercent/100
    'calc atmospheric pressure
    atm=psychro_atm(elev)
    atm_edit.Text = LEFT$((STR$(atm)),7)
    'calc vapor pressure at saturation
    pvs=psychro_pvs(db)
    svp_edit.Text = LEFT$((STR$(pvs)),7)
    'Calculate Partial Vapor Pressure.
    pvp=pvs*rh
    pvp_edit.TEXT = LEFT$((STR$(pvp)),7)
    'calc humidity ratio
    w=psychro_wrh(db, rh, atm)
    hr_edit.Text = LEFT$((STR$(w)),7)
    'calculate Enthalpy
    h=psychro_h_w(db, w)
    ent_edit.TEXT = LEFT$((STR$(h)),7)
    'calculate Dew Point.
    dp=psychro_dp(pvp)
    dp_edit.Text = LEFT$((STR$(dp)),7)
    'Calculate wet bulb temperature using an iterative method.
    IF rh <1.000 THEN
    wb=wet_bulb(db,dp,h,atm)
    ELSE
    wb=db
    END IF
    wb_edit.Text = LEFT$((STR$(wb)),7)
    'calculate Specific Volume
    v=psychro_v(db, wb, atm)
    svol_edit.Text = LEFT$((STR$(v)),7)
    END SUB
    SUB Dummyproc ' To Minimize Properly
    END SUB
    SUB Closemain
    Application.Terminate
    END SUB
    SUB reset_form
    db_edit.Text = "70.0"
    elev_edit.Text = "1000"
    rh_edit.Text = "50.0"
    atm_edit.Text = "0.0"
    svp_edit.Text = "0.0"
    pvp_edit.TEXT = "0.0"
    hr_edit.Text = "0.0"
    ent_edit.TEXT = "0.0"
    dp_edit.Text = "0.0"
    wb_edit.Text = "0.0"
    svol_edit.Text = "0.0"
    END SUB
    SUB save_file
    IF SaveDialog.Execute THEN
    savename = SaveDialog.FileName
    IF UCASE$(RIGHT$(savename,4))<>".TXT" THEN
    savename = savename + ".TXT"
    END IF
    sl1$ = "Dry Bulb Temp (F) : " + db_edit.Text
    sl2$ = "Relative Humidity (%) : " + rh_edit.Text
    sl3$ = "Elev Above Sea (FT) : " + elev_edit.Text
    sl4$ = "Atmospheric Press (in.Hg) : " + atm_edit.Text
    sl5$ = "Saturated Vap Press (in.Hg) : " + svp_edit.Text
    sl6$ = "Partial Vap Press (in.Hg) : " + pvp_edit.TEXT
    sl7$ = "Humidity Ratio (lb/lb) : " + hr_edit.Text
    sl8$ = "Specific Vol (cuft/lb) : " + svol_edit.Text
    sl9$ = "Dew Point (F) : " + dp_edit.Text
    sl10$ = "Wet Bulb (F) : " + wb_edit.Text
    sl11$ = "Enthalpy (BTU/lb) : " + ent_edit.TEXT
    file1.Open(savename,fmCreate) ' create a new file
    file1.WriteLine("Inputs Used ..............................")
    file1.WriteLine("")
    file1.WriteLine(sl1$)
    file1.WriteLine(sl2$)
    file1.WriteLine(sl3$)
    file1.WriteLine("")
    file1.WriteLine("")
    file1.WriteLine("Calculated Results .......................")
    file1.WriteLine("")
    file1.WriteLine(sl4$)
    file1.WriteLine(sl5$)
    file1.WriteLine(sl6$)
    file1.WriteLine(sl7$)
    file1.WriteLine(sl8$)
    file1.WriteLine(sl9$)
    file1.WriteLine(sl10$)
    file1.WriteLine(sl11$)
    file1.WriteLine("")
    file1.Close
    END IF
    END SUB
    'End Program
