Results 1 to 13 of 25
    Aug 2009
    michigan
    liquid filter drier -wrong direction?
    Worked on replacing a compressor on a package Lennox Heat Pump, and put a new liquid filter drier also. Put the unit back in service and everyting works okay, but then found out later we installed the liquid drier backward. Opps! We goofed up. We intend to go back this weekend when the building is unoccupied and correct it. My question is - what is the immediate consequence(s) having a drier installed backward? Thanks for your advice.
    Jun 2008
    Cincinnati, Ohio
    Restricted refrigerant flow.
    Mar 2009
    central illinois
    dude if you installed a drier backwards on a heatpump you installed the wrong drier
    work to live not live to work.
    Jan 2010
    lovley downtown central new jersey
    Quote Originally Posted by local553 View Post
    Feb 2007
    Northern NJ
    there are bi-directional driers made specifically for heat pumps.
    Apr 2010
    KY,OH,IN
    Confused
    My thoughts exactly!
    May 2008
    Myrtle Creek. Oregon
    I allways look for the two arrows for heat pump driers before installing. like what was mentioned, restriction of reff. as far as I know. I might be wrong.
    Jun 2009
    new jerseeeey
    wrong drier
    Heatpump system does not absolutely require bi-flow drier. remember those check valve guys.
    Pull the freon and change the drier before it burst.
    Dec 2010
    On a Peninsula in NE NC
    Yep, Trane uses a 1 way drier in their heatpumps.
    Mar 2009
    central illinois
    that be true
    okay?
    I will be the dumb guy here!!!!!!!!!!!!!!
    yhe drier is in the liquid line right before the evap???
    when in hp mode the liquid is flowing back to the outside unit??
    why do you NOT need a bidirectional drier???????????????
    true knowledge exists in knowing that you know nothing.
    Apr 2005
    AZ
    Quote Originally Posted by supertek65 View Post
    okay?
    because sometimes as mentioned there are regular driers with check valves. Flow is through 1 drier for heating and 1 for cooling
