Results 1 to 12 of 12
    Jan 2011
    Expansion Valve Removed 4 Replacement => NOW Water Leaking Furnace
    In December AC unit not blowing cold air. Called HVAC pro to check. No freon so recharged. Capacitor went out either during recharge or during testing after recharge. New capacitor put in but not taking up freon. HVAC tech checked condenser(?) coil & stated expansion(?) valve may need cleaning or replaced-but he couldn't be sure until both were tried. Removed expansion valve & took it w/ him to match the replacement.
    He left panel off where coil & valve were and said it would be ok & can still run heater - I'm wondering if it's really ok? Was out of town x1wk & tech can't get back to replace valve until Fri.
    Noticed yesterday water dripping...sometimes running down side of furnace (Amana 90 AC & Gas Furnace) where two 1/2" PVC tubes are located above a square grey plastic container (drip container?). The container was filled to rim w/ water. Called tech -said it shouldn't have anything to do with the valve he removed.
    Does this sound right? I know nothing about HVAC & I want to be asking the right questions when he comes back. I would appreciate any advice. Thanks
    Dec 2010
    New Orleans
    Is it oil? sounds like a lot of guess work to me on techs part. Going from no freon to bad cap. to bad expansion vlv yikes. better call company and ask for senior tech.
    Milwaukee Wisconsin
    Red Flags to me!
    Nothing really makes sense; Tech's info. & your info.
    michigan
    I would be leary of this tech. May want to do as suggested............ask for senior tech to come out.
    Jun 2008
    Cincinnati, Ohio
    The water dripping out sounds like the condensate from the furnace. Possibly a clogged condensate trap or condensate line out of the trap.
    Definitely ask for the lead tech or a senior tech........
    Jan 2011
    Thanks all. I wanted to give the tech the benefit of the doubt since he's the one with the training and he seemed like an honest guy. I wanted to find out from you pros out there whether this was the standard diagnostic pathway for why was not getting cold air & what the deal might be with the water leak from the furnace - I know for sure it wasn't leaking before he removed that valve. Thanks again.
    Jan 2011
    Quote Originally Posted by HVAC Teacher View Post
    Red Flags to me!
    Oops sorry, the tech put in a new compressor NOT a "capacitor"... no wonder it didn't make sense.
    I was outside with the tech when the unit went suddenly quiet - that's when he said the compressor went out. Once unit was recharged w/ freon & new compressor in place -cold air still not blowing from vents. He said there may be a freon leak somewhere and he wanted to check the coil then the valve etc, etc...and you know how the rest of the story goes.
    Pic #2 is where the valve was removed. Pic #3 is where it is leaking water.
    May 2008
    Myrtle Creek. Oregon
    mabie the tech had to take the condensate drain off to gain acces to the TEV, and forgot to replace it. why would you won't to leave a pannel off?
    Jan 2011
    Quote Originally Posted by cboe View Post
    Thanks I'll be sure to ask about that as well as what phbsales suggested earlier.
    I didn't want to leave the panel off -he did...but I think it was because he planned to be back the next day with the replacement part.
    Jul 2010
    nebraska
    The system is NOT supposed to be left open like that!
    Jul 2010
    Caledonia,Ontario,Canada
    Quote Originally Posted by martyinlincoln View Post
    Exactly....moisture,dirt and dust yikes......call for senior tech ASAP !!!!
    Cincinnati, Oh
    Quote Originally Posted by KluLes View Post
    ....If he CORRECTLY changed the compressor, then he would know if there was a leak, BEFORE he put refrigerant in it.
    Get a senior tech out there.
    "Just get it done son."
    Dad adjusted
