Results 1 to 10 of 10
    Dec 2008
    Trane RCTA200 Relay outputs
    Hi,
    Looking for some advise on Trane RCTA200 units connectivity.
    I have 4 of the above using local CH.530 HMI which are then connected to an central control unit called Tracer Summit.
    This Tracer View unit appears to be working its 10 yrs old all I want to do is get some local customer relays interface outputs to drive onto My BMS.
    We do this already with York YCAS chillers simple two wire connection onto the customer interface this connects straight to a BMS outstation, The out puts are Chiller run, Sys 1 fault , Sys 2 fault, Sys 3 Fault
    Any Ideas??
    Aug 2010
    UK.
    The RTAC uses the CH530 control platform. Volt free contacts are provided via an optional card. Check to see if your chillers have them, if not they can be added. As the system has a Tracer to provide comms and diagnostics they may not have been ordered. The relays are configurable with a laptop to show run, fault, etc. A laptop will also be needed to bind in the cards.
    ottawa canada
    And the magical magnetic Trane approved screwdriver !!!!!!!!!!!!!!!!!!!!!!!!!!!
    Dec 2009
    Southern US
    I never have binded an RCTA
    Or an RTAC
    And this is only a joke if this had been a real insult you would have been told to tune to you local channel.
    I'm good at making things cold...You can ask my first two wives!
    Mar 2010
    Va.
    Quote Originally Posted by graham View Post
    I'll lend him my Trane screwdriver for a small fee.
    Mar 2010
    Va.
    oops duplicat
    I'll lend him my Trane screwdrive for a small fee.
    I am not letting go of my magic screwdriver!!!!!!!!!!!
    you will need a quad elay
    and have to download techview.
    then you will need a rs232 connector
    or a usb to rs232
    I like the STARTECH!!!!!!!!!!!!!
    some rs232 to usb connectors suck!!!!!!!!!!!!!!!!!!
    true knowledge exists in knowing that you know nothing.
    Harrisburg
    If the "BMS" is Summit, that information should already be available?!? Does the customer not have a workstation/PC?
    Life is a **** sandwich.........take a bite and smile :-)
    Dec 2010
    On a Peninsula in NE NC
    Trane Magical Screwdriver. The only ones to know to flip the magnet over to reverse polarity. I am selling these for 19.95$ includes shipping. Who wants a box or 2
